newbie: sub+amp in storage box
Started by Anonymous, July 19, 2004, 22:57
hi all
i've already read some of the info from here but want to know a
very simple question.
which sub (box) + amp would fit in my mr2 roadster without a problem?
so i can just buy and fit easily.
i mean from what i have heard, it is actually getting more of a problem
trying to find a place to put them without too much major problems.
thanks
andy
GSB
I used a Musical Touch UnderDash Sub Jnr, and a kenwood amp sunk into the floor of the luggage locker;
More info on another amp that I think will fit under the floor without having to cut it.
 m http://www.mr2roc.org/forum/viewtopic.php?t=4445 m
Discussion of other amps that may fit...
 m http://www.mr2roc.org/forum/viewtopic.p ... 85&start=0 m
And finally, the UD Sub Jnr,
 m http://www.mr2roc.org/forum/viewtopic.php?t=2231 m
thanks for the pic. Whats the sub like??
i mean it does take quite alot of space. and how much did your's
cost? you got the full details of your sub? + amp?
thanks
andy
sorry, just read the links below and saw what had happened.
Would there be any other sub that would just fit in the back, on top
or next to the amp, which would make it easier and removable?
thanks
andy
GSB
The infinity Basslink fits in the back if you remove the plastic floor, but given the speed with which its owner replaced it, I dont think the results were particularly impressive.
You can always try something like this:
 m http://www.mr2roc.org/forum/viewtopic.p ... t=sub+rear m
Or this:
Also, this is a post along the same lines as your asking...
Have look through the audio forum for more, use the search to narrow it down a bit.
infinity Basslink!!
Has any1 fitted one of these on their car?
any feed back please?
thanks
andy
The basslink was good, gave bass etc BUT it made the car rattle like a BIATCH.
I replaced it because of this and that i wanted the locker space back.
I installed an amp in the bottom of the locker and some comps and dynamatted and it sounds almost as good but still with rattles, not as bad rattles but they are still there.
Its good because it can run from speaker cables OR RCA's meaning you can run it from the standard headunit if needs be, only thing about that is that the sound is MUCH better with RCA's, they are also a little complex to setup - the person to ask about setup is MrMike as he taught me  s:) :) s:)
I have my amp in the front storage compartment (w/removable shelf) and my sub behind the drivers seat in the rear compartment.  3+ yrs. and no problems!!   s:P :P s:P
Picts of my audio set-up here:
 m http://photos.yahoo.com/grafx_dsznr m
thanks for the photos, very nice car.
did you made your own sub-box?
it fits nicely on there. Have you tried fitting the amp at the storage
place? would it fit too?
thanks
andy
