Electric Windows switch on 2003 model
Started by Anonymous, July 17, 2003, 11:26
I have a 2000 model '2 and get a bit frustrated about the drivers side window switch.  It has an 'auto' DOWN but not UP, what was the reasoning behind this?
Equally as anoying is the passengers side doesn't do 'auto' up or down.
Can someone with a 2003 model tell me if this is still the case on theirs or whether Toyota have changed this?  If so, then it should be fairly straight forward to upgrade both my switches and get a new button with 'auto' on it for the passenger side - right?
Mike.
How adventurous are you?  Look here and here if the answer's "very"!...
--H--
... and no, its still the case on the 2003 model.
my j-spec has auto up on the driver side
Is it just auto-up or also auto-down..?
Quote from: "Tem"Is it just auto-up or also auto-down..?
both
