vvti
Started by Anonymous, July 26, 2004, 22:20
Can anyone tell me if theythink i'd be able to order the vvti badge thats normally screwed to the rocker cover as mine seems to be missing for some reason.
You mean the one here:
 m http://www.mr2-roadster.co.uk/photos/ge ... 300015.jpg m
If so, it seems to be one complete unit so you would need to order the whole thing.
Quote from: "speed"Can anyone tell me if theythink i'd be able to order the vvti badge thats normally screwed to the rocker cover as mine seems to be missing for some reason.
You mean you have the plastic cover without the "VVTI"...? The earlier Corolla 1ZZ-FE without VVT-i had a similar plastic without the letters...probably from those then. I'd wonder about the engine as well, if that's the case  s:? :? s:?
Anyway, you can't get just the letters, but the whole plastic thing seems to be $27.49 in US and the part number is 11212-22060.
the cars a '00, there are 2 holes in the rocker cover where there should be screws and i assume this is where the plastic cover would be attatched.
Quote from: "speed"the cars a '00, there are 2 holes in the rocker cover where there should be screws and i assume this is where the plastic cover would be attatched.
Yes..
So you're missing the whole plastic, you can get one from Toyota or maybe from someone who's parting cars, check the Sales-area  s;) ;) s;)
Get the bolts too, while you're at it..
