Head unit swap,Edit....all fitted.
Started by Markb, January 27, 2014, 22:51
Markb
Gonna fit a new Sony double din unit in this weekend,i'm happy enough with the actual fitting/wiring and a switch for the aerial....i just need to know about removing the 2 side pillar trims,i know about taking the knobs and screws out for the panel above the head unit....Thanks.
Jay67
fingers behind the bottom silver bit and prise off, just clips on, 2 screws behind it, upright pulls out at the bottom and slides down.
Markb
All fitted along with aerial switch below the ashtry......happy enough,supplied screws for the brackets were too short to go through the bracket and plastic fillers but sorted now.
chris3boro
When fitting an aftermarket stereo, do you have to do the aerial switch mod to avoid having the aerial come up whenever the stereo is on? I'd like the aerial only to come up when the radio itself is on, not the ipod etc. Thanks
s12vea
Yes aerial mod would need to be done. Nice easy switch on dash to raise aerial when needed.
Another one won't hurt  .....
