jonty
#1100
Ah OK, it does look very nice, but I don't feel so jealous if you had to get it repaired to look like that! Mine was never mint, but 2 years stored at a friend's place has left it even worse for wear... One day, I will make it nice again...
MrStev3
#1101
Quote from: "Meeerrrk"Thanks to HFB I've finally got the midship front badge  s:D :D s:D
I've also ordered a smaller front numberplate
It looks depressed after its operation haha
It's saying "get me back on track!!!"
I do like the blue especially buffed up it looks such a deep colour
Mitsuko the mr2
It cleans up well, ignore Josh he likes to take sides with my girlfriend and pick on my parking skills  s:D :D s:D
MrStev3
#1103
Race cars only need to be parked by the pit crew haha
Drive them and break them is your job haha
Mitsuko the mr2
Couple of small jobs done today.
Toyota sprint series regs state you must have a yellow negative battery cable and the positive terminal needs to be covered.
So I got some heat shrink and some small terminal covers
My steering Uj is really looking bad, I've got one in the post so hope to change that ASAP
Also fitted my new little front number plate
MrStev3
#1106
I just taped my negative terminal up and it was fine and they do check it , was the first thing they checked.
Looks good
Mitsuko the mr2
Jrichards20
#1107
Your UJ looks in a lot better condition than mine  s;) ;) s;)  put up some pictures of how you changed it so I can copy please  s:) :) s:)
Is that front number plate even legal? I've seen small number plates but that looks tiny! I would have thought a stick on one would have been better?
Need to polish those headlights next!!!  s:) :) s:)
Street Triple 765 RS
The only legal number plate is the original one, this is about half the size  s;) ;) s;)
Yep will take some pics of UJ
Dripping it off for the gearbox inspection today  s:( :( s:(
tomaky
#1109
My fronts legal i cut it down from a stock plate with the regs in front of me. Have a look in my project thread if that helps at all.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
HFB
#1110
Nice!
What parts were required and what did you do to get that tow strap fitted?
HFB
2000 Roadster
Jrichards20
#1111
Tow strap and correctly sized bolt.
Yep, a tow strap from JJC or similar, a nut and bolt, a drill and some basic hand tools. I couldn't find anywhere to bolt it so had to drill a hole, but it wasn't too bad.
Gearbox was removed from the car yesterday and is currently being inspected by a gearbox specialist. Fingers crossed for what he finds otherwise I'll be forced to buy a different box.
Also found my exhaust is blowing where a bracket has torn off, so that's another job / more money that needs doing  s:( :( s:(
Jrichards20
#1114
Bracket has torn off!?  s:( :( s:(  what exhaust did you put on there? Second hand or custom?
MrStev3
#1115
Quote from: "Meeerrrk"Gearbox was removed from the car yesterday and is currently being inspected by a gearbox specialist. Fingers crossed for what he finds otherwise I'll be forced to buy a different box.
It will still be worth it when you get back out there clipping the apex
Mitsuko the mr2
It's a longlife rear box...
Oh the irony
tommyzoom99
#1117
Quote from: "Meeerrrk"Yep, a tow strap from JJC or similar, a nut and bolt, a drill and some basic hand tools. I couldn't find anywhere to bolt it so had to drill a hole, but it wasn't too bad.
just another way to do it, we got a good quality rock climbers caribina(happened to have 1 lying around) hooked that through the original tow hole and the toe strap on to that.
I hope everything is going ok mark buddy and the gearbox is savable,
cheers tommy
My track project
viewtopic.php?t=51237
Quote from: "tommyzoom99"
just another way to do it, we got a good quality rock climbers caribina(happened to have 1 lying around) hooked that through and the toe strap on to that.
cheers tommy
Nice hint Tommy, i like that idea  s:D :D s:D
tommyzoom99
#1119
cheers tommy
cheers mate was more blind luck than anything   s:D :D s:D  , i updated my original post to say the caribina goes through the original tow hole too   s:D :D s:D  (just for clarity)
cheers tommy
My track project
No news on my gearbox yet was hoping to have the answer by now.
In the mean time I snapped up a deal from the forsale section and got a pair of unused rear AD08r in the correct size so I'll stick with them for another go before trying r888s
I also got a steering knuckle so I'll be fitting that when the car is home
Stifler
#1121
AD08R's are fantastic tyres, I use them all year round on the elise.
So far I have done 8 track days this year on them and they have hardly any sign of wear!
Jrichards20
#1122
Update on gearbox mark?
Quote from: "Stifler"AD08R's are fantastic tyres, I use them all year round on the elise.
Mine have lasted well too, I'm pleased with them so far!
Quote from: "Jrichards20"Update on gearbox mark?
Kind of, it's all gone quiet for now!
They took the box apart and found some burrs on the pinion or diff, I'm not exactly sure because this was 3rd hand info from my mate who is dealing with it all for me via his garage business.
They checked the shimming etc and seemed happy enough so last I heard they were rebuilding it and should be back with my mate this week.
They have said those burrs could have caused a grinding kind of noise but can't be certain it won't make the noise when it's all back together.
I missed the chance to buy the box from Alan - the timing wasn't good for me at all, but I've secured a corolla 2zz box which I am getting next week, my plan is to get an mr2 diff (frustrating I had one!) and get a new gearbox built up ready to bolt on should the worst happen!
I think the not-so-longlife exhaust is off and being welded up too.
