Rear toe/trailing arm settings?
Started by 1ZZ-FE, February 21, 2014, 08:20
1ZZ-FE
Having replaced my rear subframe with a FL variant, I now have to refit the rearmost trailing arms, sometimes called the 'toe arms'. To clarify, it's the ones with the ball joints on one end!
The issue I have, is that the 'plates' with the increments were so badly corroded upon removal, i had no idea they had increments on them until i cleaned them up with the drill and wire brush attachement. Realising i need to do a proper 4 wheel alignment regardless, I still need to drive it safely to where ever it is i take it. Is there a 'neutral setting' i could use to get me on the road?
Regards,
Jim
Toyota Hall of Fame = 1990 H - MR2 MK2 16v ]
Andys-N20
If it was me I would use a strip of wood/plastic and rest it against your alloys pointing down the length of the car, adjust the tracking so it is 'something like' straight or slightly pointing in towards the front. Then taking it steady on the road, get it re-tracked ASAP.
204.2 BHP Silver 2000 MR2, 2006 2ZZ engine, Apexi PFC, Zorstec full stainless system exhaust (including 400 cell cat & race header), titanium heat wrap, MRW underdrive pulleys, handmade short ram intake, Hondata intake gasket, Celica gearbox ratio's, LSD.
Edge 306 speakers, Alpine CDE 235BT, sound deadened doors.
Full facelift conversion including bracing, sub frame, the works...
Quote from: "Andys-N20"If it was me I would use a strip of wood/plastic and rest it against your alloys pointing down the length of the car, adjust the tracking so it is 'something like' straight or slightly pointing in towards the front. Then taking it steady on the road, get it re-tracked ASAP.
Yeah this is about the best way of getting your toe in roughly right, gets you somewhere to get it done properly. This is how I set the alignment on bikes and never had a problem ... advantage of a bike is it's not as long and you can measure the offset against the front wheel
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
1ZZ-FE
Can't argue with that! Great idea! I've never had a vehicle with adjustable rear suspension components and hence, not had a 'proper' 4WA done - what is it I'm actually asking for, over and above what ATS/Kwik Fit etc do when getting your tracking done? Is this a specialist job done by a motorsport expert?
Thanks guys.
Jim
Andys-N20
I don't think it is an expert job to do the four wheel tracking
I'm not sure is kwik-fit offer four wheel alignment anyway, just take it to a respectable garage and they will use lasers to get it bang on.
My local garage is an approved Bosch garage and they do it for £50
1ZZ-FE
Thanks for the info. I've found a classic Mini specialist near Lincoln that deals with 4 wheel alignment for road and track. £50+ vat is pretty reasonable I think!
Jim
