Alternator output
Started by no1trancefan, March 3, 2014, 15:55
no1trancefan
I was just wondering if anyone knew off hand what the power is of the standard alternator?
Has anyone upgraded theirs and if so what to
carlclarke
I was curious to know, I can't find a Denso specification but I did find a website with a catalogue of would could be replacement alternators here:
http://www.woodauto.com/pdf/DEN2013.pdf and on page 47 you should find what I believe is the MR2 part 27060-22100 showing as 80A. If there was a Denso specification somewhere then it would probably have a graph that showed output vs. RPM.
redarrow
Do you mean in volts?
12 volt no ignition.
13~14 volts ignition on and alternater
Is charging the battary.
If the volts for the alternator is lower
Then 12volts or goes from 11 to 12 volts while
Engine running ,  is a indecation alternator is broke
Or worn out....
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
