ignition timing help
Started by Anonymous, August 16, 2004, 19:19
what is the ignition timing on your MR-S? i checked my ignition timing today and it is 13.5 ~ 15.0 during idle, isnt it too high? is there any way to adjust? thanks
GSB
The ignition timing is a function of the ECU, and will vary wildly depending upon fuel and driving style.
What did you use to check it?
As said, the ECU controls all this, so i wouldn't worry about it, it's only idle after all. Try a reset of the ECU if your concerned, see if it alters.
Only way to alter it is with a piggyback ECU.
its something like a small PDA stuff, call OBDII automotive diagnostic or something like that which can check the ignition timing, airflow, and many other stuff.
can a Apexi SAFC adjust the ignition timing?
Quote from: "mr-s_turbo"Only way to alter it is with a piggyback ECU.
Or a standalone like Power FC  s;) ;) s;)
(I'm sure you knew that, but just in case everyone doesn't)
Quote from: "sonar"can a Apexi SAFC adjust the ignition timing?
No, that's only an AirFlow Converter...you can alter the MAF signal, which causes the ECU to dump in more/less fuel.
