Best speakers for doors?
Started by Roadster, July 25, 2014, 23:15
Roadster
I'm looking at changing my speakers (is it 16.5cm size?) but all the ones I see on amazon are basic and under £30, whats the best ones for £50-£100ish which will fit? what do you guys use? Also I live in Guernsey so i'm extremely limited to which websites/shops i can buy from
Pavett1990
In halfords they have 6.5 inch component vibe slick speakers.. put them in my car through the week.. they are awesome.. great quality and for £40 you cant go wrong really
Roadster
Quote from: "Pavett1990"In halfords they have 6.5 inch component vibe slick speakers.. put them in my car through the week.. they are awesome.. great quality and for £40 you cant go wrong really
I'll look online but theres no halfords here. is it these?  m http://www.ebay.co.uk/itm/VIBE-Slick-6- ... 3f02826d7a m
Pavett1990
Yeah thats them
AckersMR2
If you wanted to spend a little more (well more than double actually but within your budget) then the Focal 165 A1's are an excellent choice and can be picked up for around the £100 mark. Top of your budget I know but very good, had them in my 2.
Also the best spend you can make is £10 on a roll of roof flashing to line the inside of the door skins  s;) ;) s;)
My only car is a Ducati
Suzz381
If you find some speakers on a site that you can't buy from I'd be happy for u to send me the money and I cld buy them. Then cld get them sent to u via courier. Realise it wld up your costs a bit but may give u wider choice.
Offer's there  :-) :-) :-)
2001 Silver MR2
2006 Black TF127
Roadster
Quote from: "Suzz381"If you find some speakers on a site that you can't buy from I'd be happy for u to send me the money and I cld buy them. Then cld get them sent to u via courier. Realise it wld up your costs a bit but may give u wider choice.
Thank you very much  s:) :) s:)  i'll bare that in mind, i'm just sorting out my pre-cats and brakes first before i spent any more money on accessories XD
Suzz381
No probs,
I'm looking at buying these myself:  m http://www.caraudiodirect.co.uk/speaker ... ck-edition m
Gotta say I'm being typical girl and going by look of speakers
2001 Silver MR2
2006 Black TF127
AndyM
Quote from: "Suzz381"I'm looking at buying these myself:  m http://www.caraudiodirect.co.uk/speaker ... ck-edition m
None of my business really (and slightly off topic) but I used to be a fairly active member of Car Audio Direct's forum and bought all my stuff from them for my old ICE projects. Really knowledgable and helpful, I'd recommend them (although this is based on a good 5+ years since I last spoke to them).
Suzz381
Always welcome your input Andy, I'd be mad not to as u know your stuff
That's good to know as I am always a little cautious when buying online. Will these speakers fit and does it matter than my head unit is pioneer?
Anything else I would need to buy for fitting?
2001 Silver MR2
2006 Black TF127
AndyM
Yep, they should fit (pretty much the same as the ones Pav mentioned above and in the 'what have you done' thread) however I've not done any speakers in my '2 yet so don't know how much space you've got to play with for the cross-over.
Nope shouldn't matter about the head unit, they should all pretty much work with all speakers.
Anything else... you'll be soldering things so need a soldering iron, solder, flux and some heatshrink/tape. Also probably some speaker wire to wire up the cross-overs (unless they come with some) and you'll need to decide how you are mounting them (e.g. gutting the old speakers to use the fitting rings, or making some up). Also, as Ackers mentioned, while you have everything apart I'd do the door flashing to get the most out of the speakers.
It would be worth you fully understanding the install process before you start and, as I say, I haven't done it on these cars to help. Perhaps Mr Pavett could do you a little 'how-to' as he's recently done them? Might be worth a PM.   s:) :) s:)
Suzz381
Thanks Andy, all great advice as always  :-) :-) :-)
2001 Silver MR2
2006 Black TF127
Roadster
If it helps I installed these speakers... and thanks for the help guys
Auna Goldblaster Car Audio Speakers (6.5" Drivers, 1200W Max & Neodymium Tweeters) - Gold
 m http://www.amazon.co.uk/gp/product/B00A ... UTF8&psc=1 m
Which work brilliantly! Used the original brackets from the old speakers
used this guide  m http://spyderchat.com/forums/showthread ... 00-Install m
didn't need to mess around adjusting the door like he does in the guide though and i left the plastic rings on and just drilled into them.
I'm also in middle of installing a sub which should be done tomorrow
Auna AMP-CH02 Blue LED Car Amplifier (1400W Max, 2 Channel & Adjustable Low-Pass Filter) - Black
 m http://www.amazon.co.uk/gp/product/B004 ... UTF8&psc=1 m
had to make some slight alterations to make it fit though
