Passenger Side Window Not Working :(
Started by scottee, September 7, 2004, 16:31
scottee
My passenger Window has just stopped working.... and its in the down position. The drivers side is working fine.
I check the fuse, and swapped it with the drivers side fuse, and still no joy (amd the drivers side window still kept working)
Had a fiddle with the switch and the connector by the handbrake, but that didnt fix it either.
Have taken the doorcard off, but you cant get at the window motor... has anyone got any advice.... hopefully before it gets dark   s:bowdown: :bowdown: s:bowdown:
mph
The usual answer is that you've pressed the 'passenger window disable' button, to the right of steering column
'06 Black MR2 Roadster
'03 Red Lotus Elise 111S
scottee
Fixed it, the wire by the door (in the loom) had frayed... taped it up, and bingo... yay
