I've bought a turbo kit...
Started by Slacey, September 15, 2004, 18:30
No problem Sean, i'll help where i can  s:wink: :wink: s:wink:
That was why i asked about boost controller as the e-01 is a excellent addition, not only for altering boost but to do some tweaking and monitor things.
The e-manage map will be a set map that will work for any psi from 0 upto the max they have tuned to, not to just your requested psi.That way you don't have to swop maps if you do alter boost level. All will be clearer when it's all infront of you.  s:D :D s:D
Quote from: "mr-s_turbo"The e-manage map will be a set map that will work for any psi from 0 upto the max they have tuned to, not to just your requested psi.That way you don't have to swop maps if you do alter boost level. All will be clearer when it's all infront of you.  s:D :D s:D
Thanks for that Ian, there is still an awful lot to learn - and thanks for the offer of assistance, I expect I will need it at some point  s:D :D s:D
