Heated Mirror Issues - Man That Can Wanted!
Started by NeilC, September 27, 2014, 18:27
NeilC
Help!! Got heated mirrors, 5 amp wire n female spades and tried to fit them - Failed... Anyone near Halifax west yorks that can do this for me at decent price??
Fin
Where did you run into trouble? If you were willing to have a go, you're over half way there!
The roof is down on my MR2,
Fin
Which bit gave you trouble? The main skills are small hands, and advanced swearing  s:D :D s:D
bluesmoke
If I get around to doing this mod I'd be happy to help you. Don't want to say anything until I've actually done it myself though  s:D :D s:D
phaeton
Not particularly close in Worksop but if no one comes forward & you can wait till next Sunday & the weather is fine (no garage) I'll give you a hand although I've never done it before
Alan...
As Fin said, where did you get stuck?
AmeR
[MOD] Moved to electrical where it's probably more appropriate, merged duplicate thread and updated the title to assist with description [/MOD]
cabbydave
What you having problems with? worse thing I found was separating the glass from its backing. The rest was childs play but I do build doors and tailgates all day long at work.
NeilC
Ta Amer for putting me in right place, was not sure? Got door card off and mirror, did not know how to get glass off and how to wire it up? Willing to give it another go with seriouse help. Practicing the swearing part....
NeilC
P.S. Ta guys for ur replies, can travel so long as not on shift.
Fin
The old glass comes out with a bit of warmth to soften that white sticky stuff you can see on the back.
Then you need to line things up to see where to make a couple of holes for the cable. I found it much easier to feed the cable in by taking the assembly apart completely.
You need a short black cable to earth onto 1 of the studs that hold the mirror assembly onto the door, and a longer red one to feed through the rubber tube into the footwell.
Another top is to use some cardboard to remove the sticky white stuff. If you use anything metal you are likely to scrape the silver backing off.
Also use care when taking the mirror in and out. Use as little force as possible. I have installed 2 sets now and broken a mirror glass each time.  s:-( :-( s:-(
Fin
Hopefully he'scheated (like me) and bought the glass with the pad attached   s:wink: :wink: s:wink:
NeilC
Ok, how do u connect the red wire to the rear window heater switch, do u have to take dash apart? Do have the mirrors with pads - yeah!!
On the how to there is an alternative option to splice into the demist circuit in the drivers footwear. Take off the lower a-post trim and the power feed is just there.  :-) :-) :-)
NeilC
Cool, thanks!!
NeilC
What heading is that under mate?
phaeton
There is one Here
Alan...
NeilC
Thanks Allan, have another go when off work n got help, am rubbish at this practical stuff lol
NeilC
how does the passenger side wire run to the de mister cable
Through the A-post like the other side. Then run under the carpet to the RH A-post to join into the same rear screen demist circuit cable.
NeilC
Finally got mirrors done yeah!! No drilling fed wires through existing wiring, ran wires under plastics and under carpet at rear then connected to rear demister wiring under seat no splicing job done my mate is well good.
Good stuff.
The main area of pain is getting them from the door and into the body. There are a number of ways to do the power pick up.  :-) :-) :-)
It is a great mod, it even works well on water droplets too.  s;-) ;-) s;-)
NeilC
Yup my mate used a length of thin pipe, pushed that through and fed the cable through it. So glad done now
