Changing tyres
Started by kanujunkie, September 20, 2004, 23:57
Before anyone shoots me down for stupid questions, ive just had a mare of a journey home from work where on the way i got a flat right in the no hard shoulder section of the M25 roadworks. I limped her off the motorway and into a petrol station where i tried reinflating the trye and surprisingly, the pressure held, but the trye is now deformed and needs to be changed anyway.  s:( :( s:(
my Q is, do you need to change the tyres as a pair?
it's a rear tyre by the way
You should always change them as a pair; I suppose the only exception is if the other rear is nearly new and you have matched it.
thanx Heath, you kinda confirmed what i already new and didn't want to beleive. I did a 17hr shift yesterday for a bit more holiday money and now its gotta go on new tyres  s:( :( s:(
can i put different make on the back to the front though? i've still got the stock Potenza's at the mo but was thinking of putting Toyo's on, is that ok?
Quote from: "kanujunkie"can i put different make on the back to the front though? i've still got the stock Potenza's at the mo but was thinking of putting Toyo's on, is that ok?
Short answer, don't do it.
Long answer...it's ok as long as you don't try to push the car with mixed tyres, it might understeer at one point and snap oversteer at another. It doesn't matter if you only get groceries with grannystyle driving, but I hope you didn't buy the '2 just for that  s8) 8) s8)
eeeeeeeeeeerrrrrrrrrrrrrr NO!
right so its either the really expensive option or the unexpected expensive option. Doh!
guess it could be the Toyo's   s:roll: :roll: s:roll:
I had brand new S03's on the rear, and part worn stock Potenza's on the front, with no problems at all.
I guess on the track you might notice the difference when you're right on the limit, but as there's only so much "fast" driving   s:oops: :oops: s:oops:   you can do on the public roads, I don't believe it really matters too much.
I certainly drove it "spiritedly", and never felt unsure of what it was about to do!
Mind you, for the price some places charge for S03's, you could probably almost get 4 new Toyos anyway!
Tim
I had new Nankangs on the front and worn bridgestones on the back and it was fine, Untill i replaced the bridestones with new ones and then span off the road an hour latter.
Make of that what you will.
Quote from: "c_a_r_t_e_r"I had brand new S03's on the rear, and part worn stock Potenza's on the front, with no problems at all.
It really depends on how you drive...makes absolutely no difference on downtown traffic cruising  s8) 8) s8)
I had mixed tyres once and that was enough for me. The car was pretty balanced with cold tyres, but that was about it. The rears started to get warm first and then got extra grip for that and the car was understeering pretty bad. After sliding all over the place for a while the fronts got some heat as well and suddenly started to grip more than the rears and the ass felt loose all the time. And I never learned when the car goes from balanced to understeer to oversteer as it depends from the drive and weather.
On rain things were a bit different. Both tyres had pretty even grip on wet road, but the rears aquaplaned at around 60mph and always snapped loose. It was actually pretty fun when I learned how that happens...I would just accelerate to the 60mph and then the car would start spinning the rears like crazy  s:lol: :lol: s:lol:
In short...if you mix tyres, be bloody careful with them, cause you'll never know what's gonna happen next  s:oops: :oops: s:oops:
fstsven
I know exactly how you feel mate; kinda hurts, doesn't it    s:( :( s:(
Here's the situation I had last week:
On the way to work, I have a puncture. Install the spare donut, limp to dealer.  Rear tire ( GoodYear F1) is damaged beyond repair (3" bolt slashed the tire over more than 1.5").   s:shock: :shock: s:shock:     Tires where about 1/3 worn, so I decide to buy two new rears...   s:cry: :cry: s:cry:     One day later, tire fitter calls: "Goodyear F1, GSD2 AND 3, are on backorder, not available for the moment, could be a few weeks"    s:shock: :shock: s:shock:    s:cry: :cry: s:cry:     I couldn't keep driving with the spare wheel for so long (very unstable!), so I called them back...
Since it isn't advised to mix tires on this car, four (4!) brand new Toyo T1s' are now in place...    Hate losing money that way!    s:evil: :evil: s:evil:
Too bad you guys are over the channel, I have two hardly used 185/55/15 GoodYears f1 residing in my hallway, waiting to be put to use...
So, bad luck    s:roll: :roll: s:roll:     (and yesterday I noticed my right headlight steaming up   s:( :( s:(    )
2004 fire red TOYOTA MR
K&N air filter
BLUEFLAME single exhaust
3.ORACING breastplate
25 kgs extra lightness
think about it thsi way.
2 rear RE040 willcosts more thanafullset of Toyos £160 for all 4 isn't bad really.
well i ended up only being able to get the potenza's  s:( :( s:(  all dealers in my area had absolutely nothing but these for the rears. They all said the same, that they could get others in but that they would be a few days before they were in and i'm afraid i just don't have the time to be able to be without the car. So perhaps i'll be able to replace all 4 wheels sometime in the future and some decent tyres then, but it just wasn't ment to be now  s:? :? s:?    s:( :( s:(
ce la vie
guess most of my time i spend on the motorway anyway and potenza's are fine for that.
As long as you have better tyres on the rear then you should be fine - I don't think anyone has ever totalled a car due to understeer  :-) :-) :-)
As for spinning within an hour of new tyres, this will be the release agent all tyres have on them when new, you should take it easy for the first 100 miles or so until this wears off (or do what I do which is chuck the car around the first wide roundabout you get to, and bed them in then).
see my previous post
Quote from: "jblackmore"I don't think anyone has ever totalled a car due to understeer  :-) :-) :-)
Isn't that how most FWD cars are being totalled?  s8) 8) s8)
i got a punctured rear too recently, and as the other rear had only done a few thousand miles and still looked like new, i decided to just buy one tyre.
However i do have mixed tyres from back to front, Bridgestone RE720 at the back and some sh*tty Maxxis - something or other, on the front. the car is now quite hard to get the back end out as the rears have more grip than the front, which is az much safer option than the other way round as you will know when you are on the limit
Quote from: "Tem"
I think its mainly lift of oversteer which is the FWD car wrecker  :-) :-) :-)
Quote from: "jblackmore"I think its mainly lift of oversteer which is the FWD car wrecker  :-) :-) :-)
True...but as a result of understeer  s;) ;) s;)
(ok, we're going a bit OT here, I'll stop  s:roll: :roll: s:roll:  )
Comer
Quote from: "Tomr2"i got a punctured rear too recently, and as the other rear had only done a few thousand miles and still looked like new, i decided to just buy one tyre.
How is the combo of a new and nearly new tyre performing?
I've just been out on a leisurely drive and clipped a kerb at about 20mph   s:shock: :shock: s:shock:   and my new front Toyo has a very small nick in the tyre wall and it deflated in seconds.  The alloy is fine with no kerbing.  But now my car is now outside in the sun with a Postman Pat van wheel on it!!
I'm thinking of buying just the one front Toyo Proxie because I've only had them on the car for about 1000 miles if that.  Anyone strongly disagree with that?  All advice appreciated.
Michael
Now:  Black 2002 Rav4 Cruiser
in theory you should be ok, however be careful, the new tyre will need a couple of hundred miles to scrub teh release agent off, until then it will have less grip than the other front.
could be, "interesting"
Comer
Cheers Mark, I'll let you know how I get on!
Michael
