Routing amp cables from engine bay to dash
Started by adamjob, October 31, 2014, 21:14
adamjob
Running power cables in tomorrow but just wondering where has everyone ran their power cable ect to amp location.
Thinking of putting the amp under the dash fitting a baffle board under the dash too and using a free air infinite baffle 10" sub.
Thoughts and advice?
There is a gommet through the firewall behind the battery that comes out into the passenger side storage bin, easily spotted as the main loom goes through there (or one driver's side depending on which side you want), I'd recommend running it through there and then under the sill plastics to get to the dash.
adamjob
Sounds good I will have a look today.
Have you looked under the dash?
10 inch will be quite a challenge
adamjob
Yeah it's pretty tight and the pedals are causing a bit of an issue, I will keep you informed on how this goes
