Started by SuperArt, November 12, 2014, 10:25
SuperArt
Best regards,
Arthur
tomaky
I uprated my H4 pre fl dipped and main beam from stock serams to the nightbreakers id say there was a improvment of 30%
The FL bulbs are h7  s:) :) s:)
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
stewart@boro
I upgraded mine with the night breaker bulbs and then replace the sidelights with led bulbs. This has given me a consistent colour temp in the front
TF 160 TTE exhaust and style bar and other shiny bits.
Replaced by an Abarth 124 Spider
tomaky
I also put led in as my sidelight.
Westfield Seiw
Ex - 2003 Sable
AndyM
Philips Xtreme Vision for me, picked them up for £12 a pair on Amazon and they are great.
I've only for got the main beam done though as I'm using LED sidelights (and the high beam is on less than 1% of the time so I didn't feel the need to upgrade it). I'd go with the full set of these though if I did decide to.
Don't forget these bulbs still have the same power (55w).
I upgraded the Mr2 to some 80w bulbs which was the only way I found an acceptable / reasonable improvement
tomaky
Hmm tempting, to go 80w especially with the nights and morning being darkness drives.
Westfield Seiw
Ex - 2003 Sable
SuperArt
Best regards,
Arthur
AndyM
Quote from: "SuperArt"I will have to read up on how to install LED sidelights
They are literally a like-for-like swap, same fitment but have small panels of LEDs around the side and top instead of a single bulb. I'm not 100% convinced by them to be honest and may go back to bulbs though.
peteyb
I got led sidelights, i love them lol nice bright and white  s:) :) s:)
Nightbreakers are awesome just buy some
Micha
I use Philips Xtreme Vision Plus and I am very satisfied
2001 RHD Silver - Greddy T517Z Turbo - TopSecret Manifold - PTR muffler - PWR CC - Blitz 525cc -  Moroso + Oil Cooler - TRD ShortShifter - Shifter Cable Bushing - JDL Body + TopSecret Fr. Bumper- TRD Strut & Underbrace F/R - Central X bar - ZenkyRacing Coilovers - Rear Arms - Front Anti-roll bar
s12vea
Night breakers are the way to go.
Another one won't hurt  .....
mikebling
I used Osram Nightbreaker Unlimited (H4's), and are very happy with the improvement.
SuperArt
Best regards,
Arthur
tomaky
Ha i did the before and after malarky it just looks like glaring light on Camera ha
Westfield Seiw
Ex - 2003 Sable
Treboeth
Quote from: "tomaky"Ha i did the before and after malarky it just looks like glaring light on Camera ha
l viewtopic.php?f=9&t=36921&p=440495&hilit=+nightbreaker#p440495 l
Take a proper pic  s:D :D s:D
tomaky
Hehe i just took a pic looking into the headlights no idea what i was thinking at the time haha
Westfield Seiw
Ex - 2003 Sable
Osram night breakers half price at ECP link;
 m http://www.eurocarparts.com/ecp/p/car-a ... -288471545 m .
Plus if you are ordering anything else (order must be over £20) use code. Tweet5 for a 5% discount  s:) :) s:)
Shaw
I can't resist adding this.
I use h7r 4300k HIDs in my facelift projectors.
Before we all lose our minds, they 100% do not blind people as I measured lux above and below the cut off point in the beam pattern before and after fitting. They're almost identical to standard halogens (10% brighter above the beam cut off point).
To add, if you're increasing the light output of your standard lights with Osram nightbreakers or similar you'll be increase the brightness of the light that is allowed above the beam (the light intended to illuminate road signs and make you visible to other drivers) 60% ish)
#bait
Quote from: "Shaw"I can't resist adding this.
#bait
HiD kits in projectors are fine. It's when they are in reflector units that they cause issues!
Shaw
Quote from: "Meeerrrk"
#bait
Not exactly. I first put some standard h7 HID bulbs in there and they did throw a fair bit of glare. It wasn't until I changed to the h7r (with the anti glare shield) that I was happy with the readings.
Well, obviously you need to use the correct bulb...
no1trancefan
hi, are these the right ones for the facelift just to confirm cant find them any cheaper?
i can change these without splitting the headlights cant i
 m http://www.amazon.co.uk/BREAKER-UNLIMIT ... limited+h7 m
