SpyderLEE--Widebody gt300 turbo project
Started by Leethesparky, February 8, 2015, 18:22
Can't knock your dedication. Unbelievable results so far.
paul.mcgrath
#926
Fantastic car !!
2000 MRS Blue , 2004 facelift engine , Whifbitz Turbo conversion 176bhp 190lbft, hardtop ,Meister coilovers, R8 18&19" wheels, Matt brace
facelift headlights , Monocraft bodykit
Leethesparky
#927
Quote from: "paul.mcgrath"Fantastic car !!
Cheers mate
*update*
Changed the chargecooler today for a big ass one
MR2 mk3 2001 -- done some stuff to it.
My car thread---http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=53643
My YouTube channel---- https://www.youtube.com/c/spyderlee
Bullit
#928
Quote from: "Leethesparky"
Cheers mate
*update*
You got that in quick  s:) :) s:)  Have you had chance to drive it yet ? ifso was there any difference ?
m1tch
#929
Saw your Youtube video on the charge cooler - very interesting results - I am guessing the much larger core outweighs the less efficient design.
Essex2Visuvesi
#930
Quote from: "m1tch"Saw your Youtube video on the charge cooler - very interesting results - I am guessing the much larger core outweighs the less efficient design.
I think the volume af water in the charge cooler would make a difference
Lee
Did you measure the volume of water held in both Chargecoolers?
I would think the Ebay one has a significantly larger water volume
Leethesparky
#931
Quote from: "Bullit"You got that in quick  s:) :) s:)  Have you had chance to drive it yet ? ifso was there any difference ?
Yep i don't usually hang about getting stuff done.. I used to be quicker, take my time a little now.   s:D :D s:D
The core is not actually that much bigger, it's mostly casing
Quote from: "Essex2Visuvesi"
Lee
Nope didn't measure the water, but the eBay one has less air resistance..
Went for a drive today. 27 degrees cruising to peak 45 degrees after a couple of good rev limiter boosts.
Leethesparky
#932
Playing around with rear light ideas
Random pic....
tatieu
#933
Hi, what's the made of your rear diffuser ?
Essex2Visuvesi
#934
Quote from: "tatieu"Hi, what's the made of your rear diffuser ?
If I remember correctly Lee made it himself
Leethesparky
#935
Hi, yeah that right mate.. made it myself
Leethesparky
#936
Finished my rear lights. Pleased how they turned out.
How to video on my YouTube (but it's a pain to do)
Project bonnet next.
Next year is the big one — going for 400+bhp on a 1zz ,got to show people that a swap is not needed for awesomeness  s:D :D s:D
CrazySX
#937
Looks well smart Lee. Best lights out there.
Leethesparky
#938
Quote from: "CrazySX"Looks well smart Lee. Best lights out there.
Cheers dan, they aren't perfectly parallel but I must have had them apart 1000 times for various reasons, got fed up for now.. I'll sort them later. Give them the time test first, reliability
Terrific job Lee!
Looking forward for the step by step build of your engine to hit that power level (with associated videos and how to guides so we can all copy you one day...)
You should totally look into a live stream one day...
Good going on those lights.
Really fresh looking 2.
400 is perfectly reasonable from a built 1zz.
It's just the cost.
2zz swap and FI is the cheapest option for big power.
Me I am really happy with my V6.
BahnStormer
#941
400bhp?!?! What will that be? Twin-charger?
I'm loving the 1zz (still stock), but with a just a little more grunt throughout the range and it would be perfect... even 200bhp would be plenty, so I'm just looking at a compact s'charger... but I'd need somebody to fit it (no garage/workshop of my own) - extra weight, having to rev the nuts off the car (2zz) and any turbo-lag at all holds no appeal, so the relative lack of complexity of a supercharger seems the right fit for the MR2's character.
Is the front+rear downforce balanced? How is it in long, highspeed corners? I only ask as the MR2 is rear weight biased already, so I would have thought you'd end up with a lot more understeer?
I'm not looking to go the big aero route though - mine is a daily driver and I'd prefer to keep it discreet: painted calipers / aftermarket discs / exhaust (powerflow / TTE twin pipe) is the most I'd consider for externally visible changes... happy to tinker under the skin though!
m1tch
#942
Quote from: "BahnStormer"400bhp?!?! What will that be? Twin-charger?
Bore the block to 82mm, forged rods and pistons, ported head with upgraded valve train and a moderately sized turbo should make that number.
Lee - I have really learnt a huge amount from your project, its really impressive that its all DIY as well so top marks to you!
Leethesparky
#943
Quote from: "m1tch"
Cheers Mitch, yeah 82mm fully forged top and bottom, engine will be good for double that power.. only really held back by the gearbox. Match the right turbo to the setup and little to no lag. I don't get any lag now on my current setup. Supercharger s never really appealled to me. Can't see the point of something that doesn't reach its full potential until you run out of revs. If something can make 10psi of boost I want it from the beginning.
The car handles very well. Everything is nicely balanced. I give in before the car does.
Leethesparky
#944
Started a bonnet project
m1tch
#945
Quote from: "m1tch"
I am having the dilemma about the gearbox, want to keep with the 6 speed and will look to fit the JUBA gears in 3rd and 4th, apparently the 6 speed box has slightly narrower 3rd and 4th which is why they usually fail, also issues with bearing failure etc. Some have got away with running a stock 5 speed box at higher power but wanting to keep the 6 speed box, saying that the JUBA ratios are for the C60 box out the Celica so is more suited to the 2zz, they fit the C66m box we have but can mean a rev drop from 4th to 5th but I very much doubt I would still be in the power to need 5th! Good news is that with the upgraded head and cams I should be able to rev to 8-8.5k so the top of 4th gear at 8k RPM means a 129mph road speed - I have worked through all the ratios with various options. Still looking at the E153 box swap, heavy and with wrong ratios but will hold the power without going fully custom - you can get different OEM final drives though but a stock E153 with 4.2 final drive at 8k rpm would be at 146 mph in 4th.
If my car is ever half as good as yours when I am done I will be a happy  s:) :) s:)
Keep up the good work!
Leethesparky
#946
The first steps towards my 450bhp target
82mm forged goodness
8thumpers
#947
Quote from: "Leethesparky"The first steps towards my 450bhp target
Good old Santa!
Mark A
#948
Did you think about having the block pinned?
paul.mcgrath
#949
Hi Lee , will you be changing the size of turbo to be able to hit 450bhp ? I have the same whiffbitz turbo kit as you and have been told that it needs to be bigger to achieve higher power figures even with a forged engine ??
I'd really be interested in your engine plan as I've been exploring all possibilities ie  forging 1zz, 3sgte , V6 and waiting on the VAG 1.8T swap
cheers Paul
