Hot engine!
Started by a, March 8, 2015, 14:35
a
Just thought I would brighten up the engine bay lid!  s:) :) s:)
gazza1286
Looks good -  any night time shots? - please tell us how.
a
Cheers. No lights just sprayed the lid red.
gazza1286
That is a shame. The photo does suggest it's back-lit. A couple of strips of red LEDs linked to the tail lights would look great. Or is that just me?
a
That's something to think about though Gazza
gazza1286
Yeah - I had a look earlier at the possibility. Two strips inboard of the inner edge of the vents cable tied to lengths of  pvc coated metal strapping would do it. The strapping would be hidden and sandwiched between the engine cover and under tray using the existing bolts. Legal too.
a
Show the pics when its done mate.
gazza1286
Just installed the LED lights. Two 35mm strips of red placed inside some tubing and cable tied to the central spar. It seemed the simplest method of holding them in place. The wiring follows the third brake light conduit and through the inner-wing to the loom for the offside rear light.
Two shots showing the final effect. Should produce a faint glow to following vehicles in the dark.
Eastsoutheast
You could get a Good Samaritan calling the fire brigade thinking your car is on fire!!!
Looks really cool though, in a red hot type of way!
Quote from: "Eastsoutheast"You could get a Good Samaritan calling the fire brigade thinking your car is on fire!!!
Exactly my thoughts.
a
Looks great Gazza
a
Good Samaritans don't come out at night  s:) :) s:)
They probably wouldn't  " pass you by" either  s:wink: :wink: s:wink:
Ripley
Like this   s:D :D s:D
Gazbills
That looks surprisingly good! Need to add a circuit to make it flicker to add the realism.  s:) :) s:)
2ZZ-GE converted 03, black, TRD bodykit + scoops, hardtop, Meister R coilovers,  TTE exhaust with sports cat, Apexi PFC + TTE style bar & Rota Subzero 16\'s
nathanMR2
I did run a few LED strips around my car.
 l viewtopic.php?f=8&t=46086&hilit=+see+the+light l
I did do some in the rear upper vents too but haven't got any shots of those
Gazbills
Quote from: "nathanMR2"I did run a few LED strips around my car.
Just needed a set of illuminating door sill stripd to finish it off.
