Power Steering Pipes - where do they fail?
Started by gazza1286, March 29, 2015, 08:34
gazza1286
I'm planning to treat the hard pipes today as a preventative measure. I suspect that they usually fail at a particular location? But where is that so I can give it extra attention?
locobuilder brian
Look at pics on current thread " noise when turning corners" It should be clear where the most corrosion takes place.
gazza1286
Thanks -I think the problems seem to be on the bends under the front cross member and the ones near the input shaft. Now liberally coated with Smoothrite.
