Center storage bin: What is under it? Need to make holes...
Started by stounedi, April 5, 2015, 08:11
stounedi
Hey!
I'm about to install a tablet to replace the dash center storage bin. I need to run some cables (audio, charging) through bottom of the storage box.
I tried to google & search for some kind of manual what is located under it, to figure out if it is and/or what spot is the safest location to drill a hole.
Any advice on this?
andyroo104
I drilled a hole in the the rear corner next to the dial cluster but be careful ,you can reach up from under the dash to feel exactly what is there.
Leethesparky
Quote from: "andyroo104"I drilled a hole in the the rear corner next to the dial cluster but be careful ,you can reach up from under the dash to feel exactly what is there.
I drilled in exactly the same place to wire up my gauges, if you remove your dash dials(pull off the surround then a couple of screws) you can see where it comes out and feed the cables down easier.
MR2 mk3 2001 -- done some stuff to it.
My car thread---http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=53643
My YouTube channel---- https://www.youtube.com/c/spyderlee
