Which wire powers the Aerial?
Started by CrazySX, April 26, 2015, 14:32
CrazySX
What colour is the wire that powers the aerial? I am sick of it bwing erected everytime i stick the ignition on!!!
My 200sx was the same and i put a switch in so i can have it up only when needed! Although that one only came up when you put the stereo on.
This one is up regardless!!
Fin
Has your aerial been 'repaired' or replaced at any time? An after-market one was put in mine when I bought it, and I eventually found out it was wired to the ignition instead of the stereo. This can also happen on an aftermarket head unit. On the original, it is supposed to be wired so that it only goes up when the radio is on.
There is a wite-up for an 'aerial mod' which alot of people end up doing. Have a read through this:
http://www.mr2roc.org/phpBB3/viewtopic.php?f=31&t=34574#p420196
Hope it helps   s:D :D s:D
The roof is down on my MR2,
CrazySX
Quote from: "Fin"Has your aerial been 'repaired' or replaced at any time? An after-market one was put in mine when I bought it, and I eventually found out it was wired to the ignition instead of the stereo. This can also happen on an aftermarket head unit. On the original, it is supposed to be wired so that it only goes up when the radio is on.
Original gead unit and what seems to be the original aerial, but the aerial does look like it may have been fiddled with. Thanks for the link bud.
