P0125
Started by Kimitech, May 15, 2015, 20:38
Kimitech
Hello,
At first I would like to say I´ve used a search button.
My car after gutting the precats started to show a P0125 fault.
So I plugged in my diagnostic and get these interesting figures about o2 sensors:
Bank1 Sens1 - no voltage at all, but the short term fuel trim is changing a little bit depending on throttle.
Bank2 Sens1 - this one change quite swiftly from 0,1 - 0.9 V depending on throttle.
Long term fuel was about 25% but don´t know whch bank.
Sens2 - seems to be stable or once a time change, probably as it should be.
So out of this readings I´m assuming the right sensor is faulty.
How they should actually behave if new?
Weird is, that the O2 sensors were before gutting functional - no codes at all.
Sadly not uncommon that by disturbing the sensors, removing for gutting is enough to damage them. Had the same thing.
They live in a very hostile environment hot cold hot cold.
Your description of Bank 2 sens 1 is exactly what you should expect. Bank 1 sens 1 should act in the same manner.
Sparkplugs.co.uk is good place to buy, but recently many have found amazon to be cheaper. From memory DOX0204 is your weapon of choice.
Kimitech
Nicely said, many thanks.
Will check if the wiring loom itself is working as it should by just swapping the sonsors.
Bugster_MR2
I support what Ardent said above. Same thing happened to mine. Did not work after I removed/reinstalled them.
Bugster
2001 red with KW3, TRD rear brace, Zero race cat and MAF-mod.
2003 silver TTE Turbo, underbrace, sidescoops, style bar, front bumper, rear spoiler, interior garnish, exhaust
