Front wheel bearing
Started by Kimitech, May 24, 2015, 13:02
Kimitech
Hello,
I´ll probably need to replace my front right wheel bearing.
Did it somebody before - just the bearing itself? How many of them is needed, assume only one.
To that purpose I would seriously appreciate some exploded view of the front hub, own tips and tricks.
Kamil
cptspaulding
The bearing is part of the hub c/w ABS sensor. Have to replace the entire hub.
About £250 for the genuine Toyota part or £50-60 for e-Bay after market part.
What are your symptoms?
Are you running stock wheels?
I ask as they don't fail very often.
Kimitech
I have not checked it yet. But when turning right during the drive, it slightly vibrates and makes noise, not when turning left.
Stock wheels in a poor condition. Have not got a time to inspect it first.
I believe it does not have to be replaced by the entire hub.
mrzwei
What you describe does suggest a wheel bearing issue.
I think you can buy a wheel bearing kit but for the cost of the aftermarket ones on ebay it would be easier to buy the complete hub. I don't know what costs are like where you are though.
It can be a problem trying to remove the bearing without access to a press.
Ex.MR2 SMT sadly missed.
gazza1286
 m http://pages.ebay.com/link/?nav=item.vi ... 42&alt=web m
The complete unit for £50 from TCB. Not worth trying to split them at that price and no press required.
colin123bell
having my first hub changed next week they are best to fit on  front as whole hub as 2 to 3 hr hr job at garage
 then just brg change with press  on rear ones as front are quick release if you catch the mechanic garage bill its very fair on front so buy hub for 50 on ebay and go for it its the best option.rear ones take longer .
and do both at a close interval say a month of each other as it helps all round quietness and new showroom car feel come back,car will feel like new with both front done
colin123bell
Quote from: "mrzwei"What you describe does suggest a wheel bearing issue.
can the hub split easy?????have you tried it as its a small hub hence special pull apart tooling or can you press out as abs sensor gubbins in the way maybe...
Markb
No need to do them all,do them as they fail (which isn't very often).......haven't done a front before on an mr2 but have done similar bolt on hub units on other cars.....i would say a 30-40 min job. At £50 its not worth messing about with imo.
Kimitech
The bearing itself costs £20 here. So worth to maintaint the OEM hub and replace just the bearing I believe.
mrzwei
Quote from: "colin123bell"
Never had to do it on the Roadster.
Last time was on a Clio. Much bashing with a suitable sized socket, a lot of heating with a blow torch, loads of PlusGas, had to count to ten overnight, lost the ball bearings trying to get the new one in so probably a bit of grit in the cage, but apart from that, a piece of *iss really.  s:lol: :lol: s:lol:
Kimitech
So no tips and tricky for removal of just the bearing on this particular car?
Jon_G
Hi all,
I thought I'd resurrect this thread rather than starting a new one. After putting up with a random, occasional, non-specific hum for over a year, the problem has at last become significant enough for me to confidently diagnose that the cause is the front nearside wheel bearing.
I was briefly excited to see the link to a relatively cheap replacement hub assembly, but unfortunately that offer has expired. I found these current offerings on eBay, but they are double the price (but nevertheless far cheaper than from a dealer)...
 m http://www.ebay.co.uk/itm/252168325111? ... EBIDX%3AIT m
 m http://www.ebay.co.uk/itm/300777061379? ... EBIDX%3AIT m
Can anyone recommend a different (cheaper) supplier? Has anyone used these ones I've found? Any tips on doing the job (although I do have a DVD manual on the job)?
Parts are still listed on tcb parts web site.
Have you called them about availability.
I know they are still short of steering uj.
lamcote
That is not a bad option I reckon.
I have found a lot of negative reviews about the quality of bearings produced by the companies that manufacture the ones that sell for £50-60.
SKF are supposed to be good generally.
Jon_G
Quote from: "1979scotte"Parts are still listed on tcb parts web site.
Oh yeah, just found them! £33.66 + VAT. I'll give them a call... Thanks
Quote from: "lamcote"That is not a bad option I reckon.
Any negative reviews on this particular supplier?
lamcote
The poor reviews were for WJB Bearings, that is the bearing MANUFACTURER not the supplier. (I have heard nothing bad about TCB, in fact quite the reverse.)
I don't know which make of bearing TCB supply.
N.B. I have no personal experience of either WJB or TCB!!
FilipK
Hey Jon_G,
Any news from TCB? I was wondering if that's the right part as it says "Japanese Pattern Part" - not sure what this refers to?
I was thinking about replacing mine with a factored part. In the end I went OE, as they are such a rare failure.
FilipK
Is the TCB a factored part? I tried calling them just now but could not get through.
EDIT: Shit, it is bank holiday today isn't it?
Yup, today is a BH.  s;-) ;-) s;-)
What's left of it anyway.
FilipK
Luckily, they still answer e-mails!
Had a bit of a daft moment, never realised that "Pattern part" means it's manufactured by someone else.
Anyway, long story short the pattern ones are not available, only the genuine Toyota ones. Does that mean that the next cheapest option is the links posted above by Jon_G?
Jon_G
Quote from: "FilipK"Luckily, they still answer e-mails!
I caIled them this morning and - as you've already reported - they are indeed out of stock (and do not know when that stock may be replenished, if ever).
Those eBay ones are the cheapest alternatives that I found, but I'd expect to find them cheaper if I keep looking. To be honest, I was hoping for recommendations, as cheap-ish parts can sometimes be of a poor standard. I was willing to take a risk with those very cheap ones though, and then refurbish the removed hub assembly with a new bearing. We can't have the car off the road for very long as it's in regular use for work.
FilipK
I found Tora (Japanese company) wheel hub bearings in Poland (that's where I am originally from) for 35 quid - just so happens that I am going for a stag do there next Friday and will pick them up, but the sellers said they're willing to ship overseas if prepaid. Quite a difference seeing as my garage quoted me 360 quid fully fitted...
Jon_G
Well that's almost exactly one third the price of the one I ordered...
I'm a little disappointed at the cost, but it now appears to be an easy task to swap over the hubs. We've owned this MR2 from new and (apart from the radiator and the alarm) it's about the first major thing that's needed attention, so I can't complain.
I've bought a fair number of suspension and steering parts for my Honda Accord diesel (which has covered an almost intergalactic mileage) from that seller and never had a problem that wasn't easily sorted out by a phone call.
