An Ageing System
Started by 2 of the left, June 5, 2015, 21:53
2 of the left
It had to happen eventually - The aerial motor not connecting properly with the cable that pushes the aerial up and also pulls it down to it's stowed position - The garage I use for heavy jobs and things of this nature has quoted £330 ( approx. ) to refit a new one ( direct from Toyota ) - I have checked out the DIY process on the forum but using that method causes the aerial not to fully extend Looks like I'm gonna stump up!!   s:cry: :cry: s:cry:
SI VIS PACEM PARA BELLUM!!
gazza1286
What process are you following? The cheapest solution is to replace the mast for around £25.
 m http://www.mr2-ben.co.uk/products/view/ ... -2000-2007 m
