PFL fog lights
Started by Kimitech, June 21, 2015, 15:48
Kimitech
Hello, Just a quick one.
How can I wire up to the pfl car the front fog lights (using front fl bumper and fogs).
What all I need to do it and are there any guides how to?
Kamil
cabbydave
No guides but if you take the front bumper off then look at the wiring near the horn you will see a single red wire with a connector on the end this is the live to the fogs the earth lead gets bolted to the chassis. There is a space in the fuse box on the side of the dash for the fog light fuse pop one in. Then take the trim off at the bottom of the a post on yhe right hand side on uk cars and you will see a connector with 3 wires coming from it one red the same as the front wire one I think is green that comes from the light switch and another wire that is a live. You will have to get a connector to fit this and some wires to go straight to a relay then you need a switch one side goes to earth and the other side of the switch goes to the relay.
Kimitech
Thanks. What do you mean by a post? Is it the door sill cover?
cabbydave
The little bit in front of that. The a post is where the hinges bolt to
Kimitech
Maybe a picture would help.
cabbydave
Maybe you want me to take my car apart for you
Kimitech
Sorry, I did not mean it in this way. Probably know which part are you talking about. Thanks
cabbydave
If I get time tonight I will take some for you and others
