fitting tte style bar
Started by greeny, June 28, 2015, 20:27
greeny
Not sure if this is the right section for this post!
im fitting a tte style bar and im trying to determine the centre holes before cutting my plastics,i dont know if theres
a template to work from or some way of measuring
any help much appreciated
thanks
pfl black-aircon-hardtop-black leather-tte banana-tte style bar-official toyota uk bodykit
wotugonado
Yep theres a template pm me your email address I can send you a copy
greeny
Pm sent, thank you  s:) :) s:)
Barney Bear
if you have the rubber rings to fit as well make sure the holes are larger than the template size as they don't fit otherwise   s:D :D s:D
54 Sable, Air con, hardtop
greeny
I haven't got the rings unfortunatel , i will cut them slightly bigger as they do need some trim around them
Im not sure if they are available to buy anymore!
Markb
Quote from: "greeny"I haven't got the rings unfortunatel , i will cut them slightly bigger as they do need some trim around them
I'm not sure if they are available to buy anymore!
Can't remember if the bar is 45mm or 50mm......but you  should find an electrical wiring rubber grommet that should do the job.....you just need to get them with the same inside diameter as the bar thickness.A local electrical place or ebay would be your best bet.
They will need to be put on to the bar before fitting,then slide down into place.
greeny
Tte style bar fitted, thank you wotugonado for the template  s:) :) s:)
Markb
Nice job....  s:D :D s:D
wotugonado
No problem mate, looks good with the rear spoiler too   s:) :) s:)
phillip0207
hi im looking for a template for fitting a toyota tte style bar
