My Sable 2005 MR2 - shnazzle
Started by shnazzle, August 27, 2015, 15:20
MOT next week. Never been worried but this time bricking it :(
Passed!
Front brakes could do with replacing (which I was supposed to do months ago when I did the rears but got lazy :))
And I've introduced a tiny exhaust leak by changing cats. This one has a slightly leaky flexi it seems.
Lambda 1.006. That's something I can live with fo shizzle :)
No CO or HC values though. I doubt I had 0 for both. Odd
EDIT: Normal idle CO was 0.300. Exactly. So, passed with absolutely ZERO margin.  :-\  Eek
MrT
Patrick, get some catalyst cleaner from Halfords or similar, I cannot remember the exact name of it but it's a grey bottle with green and black text, ah Cataclean... Chuck it in half a tank of fuel and it is like drain cleaner, your 1zz's insides will be shiny clean and the carbon gone, and the cat will flow like new and if not knackered by heat will catalyse like new also! Worth the £8 before every MOT.
Well done on passing though, and get those brakes sorted! 2 things must always be perfect, wheels/tyres and brakes. No point going somewhere if you can't change your mind and stop again!
Tyler
Funnily enough I said the same thing before I went in for MOT. I forgot to do my yearly Pre-MOT CataClean.
The brakes are fine. It's the offside front brake pipe :(
I'm assuming the hard line. So I'll have to have a look and replace it. Luckily it's the short one so quite easy to do
MrT
Ok that's good to hear (read?)...
Tyler
tricky1138
Congrats on the new MOT, Take it the new place was ok then?
I must admit I was going to run cataclean through mine before this years, after my MOT last year said that it barely passed its emissions, but totally forgot like you did.
Mine this year flew through though. Any ideas why one year its bad and the next its fine?
Quote from: tricky1138 on June  6, 2018, 14:16
New place never happened :D I just couldn't get there and their scheduling was random. So basically you drop it off and they plan it in as and when for that day.
I chose a place local to me. Gave me an 11:30 slot, it went in at 11:30 and by 11:45 I was driving.
Can't say why the emissions would be wildly different. Too many factors.
tricky1138
Quote from: shnazzle on June  6, 2018, 14:21
I thought that might be the case with the emissions. We'll never know!
And oh, so you've found a local friendly MOT station then - 15 mins for an MOT is short!  :o
MrT
Simplest influences are driving conditions and type of fuel/additives used. Modern fuels are all about cleaning and keeping the engine clean. V-Power and Ultimate specifically have decoking agents that would clean the engine and catalyst.
Also doing a bit more high speed/higher load constant driving will keep the catalyst at temperature longer and break down deposits.
Tyler
Changed the front brakes today. It was, err, necessary.
Damn near shot myself through the front windshield afterwards
mikek
Quote from: shnazzle on July 10, 2018, 17:34
What did you put on?
Going to do mine over winter as they are not great. (Kate's were much better and I only put mintex discs and pads on hers)
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
Quote from: mikek on July 10, 2018, 18:30
Mintex :)
Can't fault them.. Until you glaze them
Quote from: shnazzle on July 10, 2018, 18:53
Mintex :)
Best not glaze them, then.  Always done well with Mintex stuff.
Mintex :)
Nice bit of Lemon Drizzle?
Discs and pads scored, warped and glazed. Trifecta of brake mayhem
tomaky
This isnt like you...                 hehe
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Quote from: tomaky on July 11, 2018, 09:40
Absolutely demolished these pads. Still tons of meat left.
Offside disc was warped by about 1mm.
The discs have worn really quickly actually, which I've never seen before.
Usually you take discs off and they still kinda look OK.
I didn't get a pic of mine but they were done. Utterly utterly done. Here's a pic of them on the car
tomaky
We talking front or back. Don't think you could get them that hot bar flooring it for a good while with the brake on. I'm impressed at the level of destruction haha
Sent from my CLT-L09 using Tapatalk
Westfield Seiw
Ex - 2003 Sable
CrazySX
Funny my discs are demolished too. They are rotten. What pads were you running pat?  Sometimes the pads will muller the disc. My yellow stuff will have nearly half left but discs are knackered and rotten. Going for brembo discs this time. These were pagid discs.
Sent from my SM-G960F using Tapatalk
Those were the fronts. Mintex discs and pads.
They've been on quite a while mind.
CrazySX
Quote from: shnazzle on July 11, 2018, 21:20
How long? Mine 3 years. But maybe 10k miles at the most
Quote from: CrazySX on July 11, 2018, 21:22
Can't find it!
I bought the set I just put on almost exactly a year ago.
The set before that was the only other set I've put on this car. I think over 3 years and 25k miles.
I'm going to need to look this up now.
Ebay purchase history won't go back past 2016 so it was definitely in 2015, possibly 2014
Plans so far:
- rebuild
- zero mani
- stg2 cams
- (maybe 2zz injectors?)
- 12:1 79.5mm pistons
- valve springs to support stg2
- competition flywheel
- 200 cell cat
- maybe different exhaust.
Added to the existing
- Hurricane intake
- bored throttle body
- emanage blue piggyback
Out of interest- say you had the above, but with an EMU Black... What is the theoretical output?
I'm just curious as to the benefits of the black over the apexi that Bernie has?
Quote from: jvanzyl on July 29, 2018, 08:52
No idea. Just more features really. So wouldn't expect the power to be too far off
