2zz wiring loom
Started by t11, August 30, 2015, 07:35
t11
Hi all...does anyone out there know of someone who can mod a 2zz wiring loom, I'am retro fitting a 2zz engine /gearbox into a 70's prototype sports coupe, i have everything out of a donor corrola t sport (03 plate) just need someone to mod the loom or a diagram on what to do, and do I need to run the aux air pump ? thanks Gordon
Escy
The car sounds interesting. Is it front wheel drive? You can ditch the air pump.
t11
Hi Escy...the car is a Gilbern t11 prototype google it and see  for yourself...its mid engined by the way
cabbydave
You could have a chat with Headcase down there hes well clued up on the pinouts of the 2zz. Slightly different car to the Invader. I've worked on a few of those in my time.
headcase
Quote from: "t11"Hi all...does anyone out there know of someone who can mod a 2zz wiring loom, I'am retro fitting a 2zz engine /gearbox into a 70's prototype sports coupe, i have everything out of a donor corrola t sport (03 plate) just need someone to mod the loom or a diagram on what to do, and do I need to run the aux air pump ? thanks Gordon
i can give you a hand but it would need car there as well  got all the data we need to get it in there and running i can come over for a jolly oneday  or a weekend . patrick if you want my help just pm us  s:) :) s:)
Patrick, can this query be answered by the text you pm'd me?
If so, I can see if I can clean it up tomorrow and post it
headcase
Yes  will help  just need a bit more info on the wiring of the car its going into have to just basically power up ecu and earths .  s:) :) s:)
Haha fair enough.
Gordon, I'm going to type something up that Patrick (headcase) had sent me on 2zz wiring, and link to it here later today.
I suggest you get in touch with Patrick for details as well.
t11
Hi Patrick (headcase) Shnazzle has informed me to ask you for some details you sent him on 2zz wiring (if that makes any sense) by the way my car is 1970 using a standard wiring loom of the time so I have a speedo rev counter oil fuel water temp and amp meter in the dash I guess I will need to know earth's live feed's and switched feed's, I will also  need an output for my rev counter, there will be an oil pressure switch and water temp switch on the engine so I guess these tell the ecu what the engine is doing so I will need to add 1 more of each to run my gauges just need to know if this is correct.....thanks for your help   Gordon
cabbydave
I recon you are going to have to run a temp sensor to work your temp gauge correctly and possibly a sandwich plate with a oil sensor on, as the voltages might not be the same as your gauges work at.
Mark A
That looks like a real interesting project, only one survives?
Shame to loose the Maxi drive train!
Bernie
Wow looks good for the age it was made !
headcase
Quote from: "t11"Hi Patrick (headcase) Shnazzle has informed me to ask you for some details you sent him on 2zz wiring (if that makes any sense) by the way my car is 1970 using a standard wiring loom of the time so I have a speedo rev counter oil fuel water temp and amp meter in the dash I guess I will need to know earth's live feed's and switched feed's, I will also  need an output for my rev counter, there will be an oil pressure switch and water temp switch on the engine so I guess these tell the ecu what the engine is doing so I will need to add 1 more of each to run my gauges just need to know if this is correct.....thanks for your help   Gordon
yes you will have to put in senser for water, for temp gauge easy one ,oil as dave says a sandwich plate sort that one .
rev counter  need to put in a converter or change rev counter  as it got go to 8,500 now
others are all the same  speedo is it cable .
i think u should  get a jdm ecu for the 2zz then dont have to sort out the coded keys .
once you got in give us a nudge  i pop over for the day
patrick
headcase
Quote from: "cabbydave"I recon you are going to have to run a temp sensor to work your temp gauge correctly and possibly a sandwich plate with a oil sensor on, as the voltages might not be the same as your gauges work at.
be like wiring in a 2gr in a h plate mr2 lol
t11
Hi everyone...thanks for the info, as I go to a lot of classic car show's with it the current engine/gearbox will stay there until the 1st week in october (which is a 3sge from the mk2 mr2) I do have all the stuff from the donor corrola t sport ecu key transponder ect, I will give you a call patrick when its in (I see you are in sussex I was in bexhill on monday for the bexhill 100 club car show it was a bit damp)....angin thats everyone for your help.....Gordon
headcase
Yes Gordon was damp lol  and the bexhill 100 lot are in the same yard as me . Pm you my tel number just give us ring if needed . Patrick
t11
Hi Bernie11a   the car was never put into production as they ran out of money and where trying to do to many things at the time as well as expanding the floor space and work force but not an increase in production so there was not enough money coming in, a bit of a shame but I do have something unique........Gordon
