2ZZ engine swop advise
Started by cabbydave, October 4, 2015, 15:32
cabbydave
Has anyone fitted the full lump from a Corolla Compressor? if so what did you do with the bulkhead. I recon with the 6th gear mod this conversion will upset a lot of boy racers and a cheap instant performance mod.
vinp182
Paul Woods has done it.. IIRC he had to cut into the firewall to get it in and the SC ended up pretty much inside the car
2001 Nissan Silvia S15 SpecR
1993 Rev4 Turbo mk2 300whp
1994 Rev3 Turbo mk2
2004 Renaultsport Clio182
cabbydave
I have seen what Paul did but I was thinking of a removable panel to get to the sc if I ever need to. After taking the Corolla out today I think some work would be needed on the front of the Mr2 to keep the front end on the floor as I recon it will be good for 160 with the 6th gear mod
