Banana Car
Started by justinread72, December 5, 2015, 09:47
justinread72
#75
So today was Raptor day and what a great product it is! if you doing just wheel arches just one bottle for our little cars. I used two bottles and it all got a good coat and here are the results if you want any advice on this stuff just send me a PM
Anyway here are the results and next weekend I will be putting bits back on ! sub frame back this week wish bones to have new bits pressed in and caliper  kits on there way from Germany .
justinread72
#76
oh and want to take some weight out your mr2 !
take off rear inner wings and loose 4 kg of dirt !
justinread72
#77
so I did my first ever ebay order from another country
the brakes need a service kits and cant find the front kits with pistons so went to Germany I saved 25 Quid in total
I was thinking we need a area on  the forum for where we can put what we brought and how much a data base of good deals   s:idea: :idea: s:idea:
when I have finished I will put together where and how much everything cost and where from in case anyone is interested
Sounds like a good idea to me
J03
#79
Wish I'd known, I've got a front refurb kit with pistons that's surplus to requirement.
justinread72
#80
Quote from: "J03"Wish I'd known, I've got a front refurb kit with pistons that's surplus to requirement.
ARRRRRH !
pm me any stuff you don't need I need a rear Kit?
J03
#81
I do have a nearly new N/S rear caliper if you want it?
Jrichards20
#82
Just read this, looks great! Definitely going to be copying the raptor and the cleaning etc that you've been doing. Looking forward to following this!
Keep up the good work.
Street Triple 765 RS
justinread72
#83
Quote from: "Jrichards20"Just read this, looks great! Definitely going to be copying the raptor and the cleaning etc that you've been doing. Looking forward to following this!
Many thanks I had new wheel bearings today and tomorrow I start putting the banana together!
justinread72
#84
man flu no work today
UJ arrived and compared to the old one it was so bad !  TCB car parts amazing service
justinread72
#85
Finally man flu gone sort of ! I put some parts back on!
I also got some more deox C  I tried the gel and just did not find it any good so rear hubs are being soaked
so the ABS bracket is 90 quid so I spent a few hours sanding and prepping and then powder coat and its come out good
so far this
J03
#86
Looks cracking bud  s:) :) s:)  Nowt better than a proper job!
justinread72
#87
sub frame all welded up by Bonsia  spoon collar kit and on at the weekend along with lots more bits
starting to get the tie bars all ready for powder coat also think gold colour we shall see
justinread72
#88
powder coated subframe check !
Spoon collar kit check !
Wishbones wearing sexy new white line bushes and new ball joints check !
busy easter !
lamcote
#89
Why did you weld the subframe, had it rusted or is it a performance upgrade?
justinread72
#90
Quote from: "lamcote"Why did you weld the subframe, had it rusted or is it a performance upgrade?
The subframe was in really good condition you will see i had trouble getting the camber bolts out !
Once out Andy at Bonsai welded up the subframe to make it stiffer and stronger. I also have a spoon ridged collar kit so it will stay in alignment and with my coil overs a poly bushes will be well sorted and future proof.
I was going to ask that to and what the spoon kit was for.
Looks good.
justinread72
#92
Quote from: "1979scotte"I was going to ask that to and what the spoon kit was for.
Looks good.
The spoon kit works in essence taking the factory tolorence out. If you lossen all four bolts that hold it to the body it's moves a lot and the collars stop any moment. Andy at Bonsai has had before he set he is mr2 up all the geometry and cause there so loose on the bolt holds it goes out quick.  I will post some pics.
This on our cars is a very important upgrade .
justinread72
#93
I have moved the alarm from the Frunk lots of little things done today
prepping the rear hubs
Thats a nice little gap you have found for the alarm!
Its all coming along nicely.
justinread72
#95
Quote from: "Topdownman"Thats a nice little gap you have found for the alarm!
I found it ages ago just fitted today properly really pleased it's out the way hope that helps others
justinread72
#96
long weekend and seams like I got nowhere !
anyway production line working well just the trailing arms to do.
I think we have another FGRob on out hands here.  s:-D :-D s:-D   s:bounce: :bounce: s:bounce:
justinread72
#98
Quote from: "StuC"I think we have another FGRob on out hands here.  s:-D :-D s:-D   s:bounce: :bounce: s:bounce:
I have just seen his work on the spit ! Amazing. I do however have my next project in my mind. ,
You saw bernie's car at the meet. That is rod's old car.  s;-) ;-) s;-)
