Tyres with Rim Protection Bar - worth it or not?
Started by HFB, February 15, 2016, 13:52
HFB
Looking at AD08's on Tyre Leaders site.
205/50/15s are £89.00 with Rim Protection Bar and £84.50 without. and £74.60 on 185/55/15's - only have RPB option.
What is the benefit of having the bar (when being used as a track car)?
Does it improve stability etc or is it just in case of a blow out?
HFB
2000 Roadster
Eastsoutheast
I thought it was just an extra bit of rubber sticking proud of the tyre to protect your alloy if you get too close the the kerb.
+1 , I believe that some tyres feature a protruding bead for this purpose, alternatively a separate bead can be fitted between tyre and rim these  are a solid plastic and come in various colours.
ChrisGB
Quote from: "Joesson"+1 , I believe that some tyres feature a protruding bead for this purpose, alternatively a separate bead can be fitted between tyre and rim these  are a solid plastic and come in various colours.
AlloyGators, they're called. A couple of instructors I know rate them.
JoeCool
Of no benefit to a track car, it's just additional weight.
if you have no trouble parking, get the standard ones.
2ZZ '02 Roadster
