Driveway Turbo Build
Started by keljon, February 16, 2016, 15:27
Good work.
Not heard anything bad about innovate gear before.
Do you think you just got a dodgey sensor?
Is the AEM ?
stupink
Innovate certainly used to need calibrating in fresh air, *then* install the sensor. Bit of a pain in the bum really. Aem just plu and play.
keljon
possibly a dodgy sensor but if you google it, you will see a lot of people have problems with the innovate kit so i decided to replace it with an AEM wideband which i have heard great things about.  certainly very easy to install
Mark A
Good progress
What clutch you using?
How did you do this and does it work ok?  "i have both manifold sensor plugs running off one sensor"
stupink
Quote from: "Mark A"Good progress
Been  running mine like it, works well, just put the signal to both inputs, and put a resister across the one that doesn't have a sensor so it thinks the heater is working(or leave old sensor plugged in)
keljon
It's an ACT HDSS rated for 150 - 299hp and upto 233 lbft
Initial impressions are great, slightly heavier pedal but feels stock apart from that.
Both manifold plugs are wired to a single sensor and I have a resistor on the post cat sensor.
Mark A
Sorry, I was interested to hear if you'd spliced and joined the wires, which ones or did you by a plug & play option?
Just interested in a bit more detail as I think this is a neater option than another sensor in the downpipe for me.
keljon
Yeah spliced and joined the wires for the manifold sensors so it's all wired to a single sensor
keljon
here you go, second post down shows you how to wire it all to one sensor
i used crimps and shrinkwrap because you cant really solder the cables very well as they are stainless i think
 m http://www.spyderchat.com/forums/showth ... x-solution m
Mark A
