Adjustable rear arms
Started by J03, March 21, 2016, 15:25
J03
This is for any of the guys who run adjustable rear arms. Is there enough adjustment to ditch the toe bolts completely?
MilesH
If you mean the standard bolts on the subframe that allow for toe adjustment then yes.
I ran Topspeed rear arms and between the three of them they gave me full adjustment for camber and toe. I put a spot of weld on the standard toe adjusters to make sure they didn't move.
Hope that helps.
J03
Cheers bud, that's confirmed my presumption. I'm having a rear frame fabricated & ditching the toe bolts makes the process simplar.
