Head gasket
Started by Andystubbs, May 13, 2016, 18:43
Andystubbs
Hello any body had to replace a head gasket, just woundering are any
Special tools are needed. I have a torque wrench and other baisic hand tools
A timing belt isn't involved, have done a few on different cars over the years.
Do i need new head bolts or will the old one's be ok etc...any advice appreciated   s:D :D s:D
beavisrules
Head gasket problems are rare on the 1zz
Stretch bolts , so unless you feel lucky then yes , replace them.
There's a youtube video of someone doing the whole rebuild on a 1zz , although on a corolla.
 m https://www.youtube.com/watch?v=A595LR4SQpI m
While there you are only and extra hour from replacing the pistons/rings. another hour to do the valve oil seals.
gl.
Quote from: "Andystubbs"Hello any body had to replace a head gasket, just woundering are any
As already said, a rare failure.
What are your symptoms?
Sent from my D5803 using Tapatalk
As above. Why the need?
