Main Menu
T-cut
Started by a, June 22, 2016, 20:13
a
Anyone used the T-cut headlight cleaner?
nimrod
T-cut has some effect, also tooth paste and Brasso I have used all 3, but to get my headlights perfect I really need to split them as some of the dulling is inside the light.
I think most polishes will do the job but if you dont then do something to stop UV then the problem just comes back. If you have really bad ones you may need a proper kit with the wet and dry etc. You can get UV sprays or use a UV resistant clear lacquer after polishing.
Mine werent that bad so I had been using ordinary t-cut by hand but recently have lacquered mine so hoping it will last longer this time.
The Other Stu
I bought the Quixx kit. It not only comes with everything, but also has UV spray.
insx
I bought the Quixx kit too. I had it almost done in a lunch hour.
Nostromo
I used this stuff befor and actually worked quite well. Just needed a bit of elbow grease to get a really good finish: http://www.detailing.com/store/meguiar-s-perfect-clarity-headlight-restoration-kit.html?gdffi=acdb1f1dcc25482d9ccd35b60adf4af6&gdfms=365D54DB723F4F6E8463A052EF6A2A67
