losing my memory
Started by jazzsumo, July 27, 2016, 12:36
jazzsumo
I've installed a double din but it does not remember any of the setting from each time I turn it on .  Wiring loom converter from Halford where can I get a memory feed so it does not forget or is my unit knackered. Its a Pioneer AVIC-F930BT but quite old now.
tricky1138
Quote from: "jazzsumo"I've installed a double din but it does not remember any of the setting from each time I turn it on .  Wiring loom converter from Halford where can I get a memory feed so it does not forget or is my unit knackered. Its a Pioneer AVIC-F930BT but quite old now.
Its been a while since I looked at mine but if I remember there are two feeds coming into the radio, switched live and permanent live. One Red, one yellow.
They used to have inline fuses in them and you could just swap the wires around if that happened. Dont know if you can now, but that is what needs done.
jazzsumo
Thanks I'll have a look at that.  I've also got to plug inn muy new mic into the head.  So I'll have to pull it all apart again grrrrr.
tricky1138
Quote from: "jazzsumo"Thanks I'll have a look at that.  I've also got to plug inn muy new mic into the head.  So I'll have to pull it all apart again grrrrr.
Should be able to get to if from the side?
I certainly got my mic plugged in without taking apart.
