Removal of Windscreen Pillar Trim for DAB Aerial
Started by Hamphlet, August 21, 2016, 21:21
Hamphlet
Hello Everyone. Just looking for some help. I'm about to try installing a new windscreen mounted DAB aerial and it looks like it involves removal of the pillar trim to allow the earth pad to make contact with the metal and also to hide the wires. I believe removal of the trim involves the undoing of the soft top clip at the top of the windscreen. I've read so many horror stories about the torx bolts these clips are held on with & wondered if anyone had had any success without having had to drill the bolts out? Alternatively is it possible to pull the trim away just enough to allow installation of the aerial without undoing the clips? I'd be interested to know what tools have been used successfully and which methods, heat, WD40 etc.....
Many thanks
wilko59
Fitted my DAB aerial on Saturday, 10 minute job.  Fitted on left side to past small fuse and into back of stereo that way.  Torx bolts off on passenger side, they were very tight still but came off and on without a problem.  2 bolts holding the panel covering the left side of the dash then prised the pillar trim away.  In and out in ten mins.  It's helpful when fitting the stereo in these cars that the back of the stereo is quite accessible if a bit untidy.
Red Edition -  Widermuller\'s bling, short shifter, ultimate gear linkages and billet cage mounts.  Garage59 manifold, Proflow quad exhaust and sports cat.  Kenwood/Garmin DNX.
Previous - PFL Blue H/Top & MRs Black 2zz
Hamphlet
Cheers Wilko. I'll be giving mine a go at the end of the week. I may try heating them up first before trying to undo them. I'm scared that either the heads will shear off, or the torx shaped recess will just round off. What tool did you use?
cabbydave
I didnt bother with the stick on aerial just bought a splitter off ebay that uses the factory aerial for the dab
monkeybrain1234
I have a stick on DAB Aerial on my 350Z windscreen, rubbish.  Would recommend a proper one that you can hide somewhere.
Hamphlet
I'm going to 'stick' with the stick on aerial for the time being as I've already bought it and I've heard a lot of people complain about the adapters for the existing aerials too. In the end I suppose there's no substitue for a brand new body mounted DAB aerial but I've been trying to avoid the cost if I can. I've also been trying to avoid hassle and to that end I was encouraged by a photo I saw showing someone pulling the pillar trim away from the pillar just enough to gain access. I tried it & it pulled away quite easily. Only on the outer edge though and not on the windscreen edge. As it stood it was useless so I tried pulling the top section away from the bolted roof clip that had been giving me nightmares. To my surprise it pulled away quite easily and from there on it was relatively easy to pull the whole trim off. So, for anyone thinking of fitting a stick on aerial onto the windscreen, this could be the way forward. Yes it was a bit of a fiddle getting it back on again, but my amateurish hands managed it in a couple of minutes. The main plus is that I no longer have to worry about undoing those dreaded torx bolts on the roof clips. Tomorrow I'm going to remove the original radio and replace it with the new DAB/bluetooth affair (Pioneer MVH-X580DAB). Are there any further pitfalls/sticky areas I need to be aware of?
Hamphlet
The radio is in. No major hitches, just took a long time. I followed a helpful youtube video with regards to removal of the original one. The fascia adapter I bought turned out to be for more than one car and needed optional bits to be sawn off so it would fit. I'm more than happy with it & so far DAB reception has been very good, though I have yet to test it in the middle of town where it can sometimes be a bit hit and miss.
monkeybrain1234
DAB signal always seems a bit hit and miss and sometimes where you would think there is great signal there is not, hope it works out.
Hamphlet
So far dab reception has been faultless. Even in areas I've had problems with in the past. And that was with factory fitted aerials. I've earthed it properly and took some paint off to make sure. I'm guessing this makes a difference. I've seen reviews saying that these aerials have started off very well but have deteriorated over time. My suspicion is that it's the earth connection which has failed. Anyway it's all good at the moment. Time will tell.
mulaz
Do you not find the sound quality of DAB is flat and Mono compared to FM or Mp3's?
Slowly replacing all the old parts for new parts so that one day i will end up with a brand new car !   s]
Hamphlet
You may have a point but I like DAB for the extra channels I can get. Particularly 6 Music and Jazz fm..
Skint Brit
Late reply but my experience may prove useful to another member contemplating removing these bolts. Firstly as I think has been mentioned, they do come supplied from the manufacturer with a band of thread lock applied, this combined with the relatively shallow star head can make them a swine to remove. The first word of advice I would give is to make sure you are using the correct size socket (the size smaller will fit, and seems to grip, but will round off the surfaces when pressure is applied), and make sure you keep the socket wrench at 90 degrees to the bolt head whilst applying firm constant pressure. Keeping 90 degrees is difficult at the best of times due to the angle of the "A" pillar, but trying to keep it whilst applying anti-clockwise pressure is a two person job.  If you do muck the head up, it is possible to drill a new (sharp) 4-5mm HSS bit through the shaft and use an "easy out" reverse thread extractor to remove the bolt, take your time making sure you are drilling the dead centre of the bolt, as there is not a huge amount of leeway before you come out the side and hit the pillar. I would again recommend another pair of eyes to keep you central and level.  Apply plenty of WD40 to the reverse of the bolt (access holes in the a pillar) and again use firm constant pressure. New bolts are available from Toyota, their part number is :90148-80046. Oh and if you do have to put new ones back in, I would suggest removing the threadlock first. They are still tight, and even if they started to loosen, would not just fall off the pillar without you noticing a loose bracket the next time you open your roof. I hope someone finds this useful. Thanks guys and girls.
Very nearly a 2007 model in Silver. TTE exhausts, spoiler and suspension. Black & Silver Grey custom leather with A/C. New Carhood Warehouse Mohair roof & Pioneer Avic-F77 head with reversing camera. FTSH.
Do you have the exact size of the correct torx bit?
I started taking mine off but abandoned it as it was starting to round. It came loose and I got about 3 turns but then it locked.
Skint Brit
Quote from: "shnazzle"Do you have the exact size of the correct torx bit?
Lol, I thought someone was going to ask that  s:D :D s:D   I don't remember it off hand but will get my sockets out again tomorrow and update you. All I remember is I thought initially that it was the smaller one.
mulaz
You can remove the trim without removing the roof catches. The trim slides under the catches
Skint Brit
Quote from: "mulaz"You can remove the trim without removing the roof catches. The trim slides under the catches
"Removing" wasn't an issue for me, but trying to re-fit I couldn't get it to slide in. I guess if I had used a rubber mallet it might have gone, but at the time I thought "just remove those two bolts...........how hard can it be?!!!"   s:roll: :roll: s:roll:
Indeed. Removal is easy but refitting is a nightmare because of one of the plastic hooks. It flexes too much. I had an absolute nightmare fitting it back. Hence me trying to remove the bracket
Skint Brit
I've had a look at what I used successfully (after mistakenly using one too small) it appears a T40 is the correct size.
Cool,thanks  s:) :) s:)
treeroy
sorry for the thread resurrection but HOW THE HELL DO YOU GET THESE BLOODY TORX SCREWS OFF?
With the correct size bit, something like an impact driver oh and a lot of luck?!
Are you a man of God?
It may be the thing that cracks it.
The only thing I've heard work is an impact gun.
That's how Dick Sloan gets them.
Bossworld
I was able to manipulate mine out of the way slightly, but, if I remember correctly someone advised me several years ago that careful use of a sharp Stanley blade where the trim meets those clamps means you can lever the trim out without undoing the bolts.
For DAB you need to make sure the sticker is touching metal so will need to manoeuvre it one way or t'other.
If you are going to attempt to undo them please please verify the torx size as the bolts are made of cheese.
Correct. I removed mine without removing the screws.
Took about 30 mins of fiddling per side to get it back on but I did get it done. I remember thinking that next time I would use a flexible rod to tie a wire to if I desperately needed to thread it through there again
treeroy
Quote from: Bossworld on September 26, 2020, 21:35I was able to manipulate mine out of the way slightly, but, if I remember correctly someone advised me several years ago that careful use of a sharp Stanley blade where the trim meets those clamps means you can lever the trim out without undoing the bolts.
I want to do it properly rather than getting it out, as above said it would be a pain to get back in.
The Torx size is T40.
Don't think I have a powered impact driver. Only got screwdrivers. If I had a spanner to get some leverage on it, would be more useful. Just can't get enough strength to twist the screwdriver.
