thoughts cda-9812rr
Started by kanujunkie, January 15, 2005, 17:00
as it says
details located here
I'm happy with mine (in the Leon, which has crap stock speakers - haven't got around to replacing them yet), and it sounds good enough to me.
cheers phil, i just wanted to hear it was ok from someone before i bought it,
thanx
GSB
I had an older version in my last '2, and loved it.  It was a pain in the arse to set up so it sounded good, but once there, it sounded excellent. Also, the seperatley controllable pre-out for the subwoofer is a god send. It allows you to change crossover, phase and levels from the head unit. Which cuts hours off the setup time when you have a multiway system.  I think they've updated the sound controls to be a little easier to understand now, so set up should be better for you now.
To save you having to do all the tedious maths, I've worked out the folowing settings for you...
Bass focus should be left at zero with an underdash sub, probabley not more than 0.4 with a sub in the rear...  And when setting the time delays on the Adjustable Time Correction feature, leave everything set at zero except the Front Right channel, which you should set to 1.2mS... This is probably one of the main things I miss on my new Blaupunkt, the difference it makes is hard to believe.
Looks nice
at 60 watts the stock speakers will beg for mercy - I have blown my with 4 x 35w.
cheers for the advice Grant, should come in useful when i get all the gear in. I need a bigger shoe horn though!!
Quote from: "TheRaven"at 60 watts the stock speakers will beg for mercy - I have blown my with 4 x 35w.
They would but i've got 6.5" Bazooka marine rs series speakers in the front connected to a Bazooka p250 amp and another p250 amp connected to 2 6x9's and lastly a dual voice coil 10" sub connected to a p500 monobloc amp. Gonna sound goooooood  s:wink: :wink: s:wink:
only thing stock is the door tweeters
well seeing as it's my birthday, Ele has gone and bought me one  s:D :D s:D  gonna look very cool with the red and black combo,
