Wiring in spot lights!
Started by Anonymous, January 17, 2005, 17:50
Hello all,
I have just fitted spotlights to my 01 '2'. I have managed to feed all the wires through i.e. power, earth, switch etc but in the instructions it tells me to wire from the switch into the main beam circuit and tells you to refer to the handbook for the colour of the wire. I can't find this and was wondering if anyone new it off the top of there head which one it was. Correct me if I am wrong but surely if I just run the earth and power to the switch it should work to. Wiring it into the main beam circuit would just mean they would go on and off when the headlights are on.
Help I am thick!!!!!!!!!!  s:? :? s:?    s:? :? s:?    s:oops: :oops: s:oops:
your correct, however thats rather the point. UK regs require it.
Do you know the colour of the wire then?  s:) :) s:)
Jap GT300
Quote from: "chrisonite_100"Correct me if I am wrong but surely if I just run the earth and power to the switch it should work to.
Just do this bit.  That is all I have done on my fog lights!
