Mr2 2zz supercharged
Started by culmen, October 28, 2016, 21:29
Very nice mate
SDB278
Awesome build, excellent work.   s:bowdown: :bowdown: s:bowdown:  Where did you get the main instrument dials?
culmen
Thx!
Soon first trackday tests.
@SDB278
You mean dash?
 m http://moman.pl/eu/ m
The only problem is stock dash is not prepared for 8krpm+.
SDB278
Yes dash. Many thanks!!   s:) :) s:)
inside
Awesome build culmen!
Could you explain how on earth can you run on stock 2zz ECU? And with stock injectors?
Quote from: "inside"Awesome build culmen!
You can do it on a stock 1mz with the trd charger at 4psi.
There is also a 2gr i know of doing the same thing.
culmen
Stock celica 2zz ecu is running on autoadaptation.
Its very simmilar ecu to 1zz ecu (propably other too)
If You are intrested about autoadaptation I can write some about behavior.
And about fuel injectors.
They are stock but we increased fuel pressure.
If you know a lot about the Toyota ecu auto adaptation, can I ask you to explain in the LTFT Emanage thread. Please?
 l viewtopic.php?t=57975 l
Or
 l viewtopic.php?t=54259 l
inside
Quote from: "culmen"If You are intrested about autoadaptation I can write some about behavior.
Yes please do, I'm very interested in this!
Would you say this is easier to do than e.g. custom tuning on PFC?
Also would you say this is more / same or less reliable than custom map on standalone ecu?
culmen
Im back  s;) ;) s;)
About autoadaptation.
It seems raliable.
Corolla did over 150k km on that setup. And i get no engine fault in service history.
Mr did few kkm already (2 track days and over 300km on tracks already)
and almost no bad signs.
At 1st trackdays "Kielce 4nano time attack" was very hot and i had some problems with temperature water/oil
I changed front radiator to mishimoto. Problem solved water dont exced 90c already and oil temperature drops too.
On next TD "Autodrom Jastrząb" only twice oil  reach over 120c (about 1km slower and temp drops to 100c)
mikek
I want flames!!!
New little car to follow soon
Ex 2zz by Rogue. Se7en cams. BMC CDA. Competion clutches lightened flywheel, Megillian Racing Exhaust. TRD sportivo suspension and ARB\'s. TRD braces. TRD quick shift. TRD dash kit, Matts brace. Getting there but not sure when it will stop!
culmen
#36
On Kielce trackday i had problem with fuel.
On 1/4 there was not enough fuel in corners and afr goes low.
Second problem. After 2 sessions i run out od front brake pads.
I was to "hungry" and i was pushing hard still  s;) ;) s;)
Ordered again front ferrodo ds2500 rear yellow EBC
jonty
I think fuel starvation at that fuel level is normal, I get it on roundabouts on my way home from work. Maybe you can sort a swirl pot? With your fabrication skills it can't be too hard! The car looks great so keep on showing us your efforts!
culmen
@jonty
Most tracks im running has fuel station in about 5km.
Another event finished without big problems. 4nano Koszalin time attack
(Just fuel starvation and raising oil temp)
Im trying to not drive when temp reach 120c. I know its super afe temp.
This time i used yokohama a048 tyres on OZ Superleggera rims.
Front 205/50 r15 soft
Rear 225/50 r15 medium ( left tyre scrubs from fime to time on bumps.
And fotos from Motopark Koszalin
More photos here:
 m http://seat-racing.pl/foto/index.php?/category/44 m
culmen
Car survived another trackday.
Kielce circuit.
Rainy/wet conditions makes that place slippy as ice.
There are 2 or 3 different asphalt with various grip.
I'm going another track day this sunday.
delhusband
#40
Love your car, driving that on track looks like fun. And the flames in your other pics is like Smok Wawelski from Kraków!!
culmen
#41
Another trackday survived  s;) ;) s;)
Car is still reliable. This one without any problems.
This year i did total 9kkm and about trackdays 700km.
This time i was 7th
Place 1 & 2 are errors.
It's sacond to last session not fastest.
I was very tired already and few times failed gear change.
After 10min tires were overheated.
[youtube:29x6x04c]S1tEU4fO2D0[/youtube:29x6x04c]
culmen
#42
New race year has begun!
https://www.youtube.com/watch?v=fKuGVnd52FY&feature=share
https://www.facebook.com/rajterkrzysztof/photos/a.435092106951599.1073741854.327472071046937/435099323617544/?type=3&theater
After winter i had some problems this time.
Some problems with 3rd gear.
And i was not able to remove sillencers!
I remove screws and i shot left on track.
Another problems was tyres.
Wheather forecast says 0c-5c and wet conditions.
I choose toyo r1r. I killed them on 1st session  :-\
They are goot for daily use but they are not enough for dry track in 15c.
Next track Pixers ring 15 april
Stay tunned!
culmen
Finished another 2 race / Time attack rounds.
Pixers ring but i dont have any foto. And any good results too ;)
But next round was much more succes full.
I bought tyres.
Front michellin 19/57 r15 Medium
Rear dunlop 205/555 r15 Medium
And goes autodrom Jastrząb track for Avalon Extreme race Day.
Then weather changed :D
https://youtu.be/jJrWHYwXbeU
Finished 2nd in class because mine last run was on semi wet conditions.
Finished because i choose 1st gear instead of 3rd.
Engine is working but making strange noise. Need to repair.
culmen
s12vea
Ex TTE Turbo
Another one won't hurt  .....
culmen
Some another event.
Finished 15 in overall.
https://rajd.internetowy.pl/results/25
And free ride with passenger after.
https://www.youtube.com/watch?v=CSXrykUkxGs
