Key lost...help
Started by bazza, November 11, 2016, 21:18
bazza
Hi all
Big probs, Today I have lost the grey master key. The one with the dog tag with the no. on it... this also had the only fob I have attached to it. I have 2 keys that fit the car, neither with a fob in them
WTF do I do now?
The car is currently unlocked on a works car park.
cabbydave
Firstly sorry to sound blunt but when will people get it into their heads the grey key is not the master key. Its a Valet key and cannot programme anything nor open glove box its made for thieving valeters. Right rant over, Get yourself a spare transponder and then you can programme your alarm . Do your black keys work the car at the moment if not your a bit stuffed unless you change the locks and ecu nightmare. If your desperate and you have transport to get up to Manchester I can sort you a lock kit and ecu with 2 keys anytime. Or sort you with a transponder and ecu to enable you to use your present keys.
I hope this doesn't break any forum rules and sorry about the rant.
bazza
I have the original 2 keys, both without the key fob thingymabobs in them... that's it. Like a blank . Both keys open the doors, fit the ignition, but the car won't start.
Bongo
Not sure they're the original keys then!
cabbydave
Quote from: "bazza"I have the original 2 keys, both without the key fob thingymabobs in them... that's it. Like a blank . Both keys open the doors, fit the ignition, but the car won't start.
In that case you need one fob and a ecu i can sort you tomorrow if you want to pop up to Manchester
cabbydave
Other way you could do it is use a mrs ecu as  you dont need the chip with them
bazza
Quote from: "cabbydave"
I cant 2moz , I'm a lorry driver. I'm in high peak and coming through stockport around 12 mid day ish on monday,,, How much we talking dude?
cabbydave
Quote from: "bazza"
PM me we can sort something out I have just put a apexi on my car so I have a fob and ecu I can leave at my mums on monday I'm in Bramhall near Hazel Grove if that works for you.
cabbydave
Quote from: "bazza"
Quote from: "cabbydave"In that case you need one fob and a ecu i can sort you tomorrow if you want to pop up to Manchester
If you want the ecu and fob still give me a ring on 07714243860 or txt I can leave in somewhere for you tomorrow so you can collect
bazza
Hi all,
Just to post an update, thanks to Cabbydave, I now have a running roadster...   s:D :D s:D
Swapped ECU's altered my one and only original key to fit the flippy transponder & followed the thread about reprogramming the transponder to the alarm....
It all works!!!!!!!!!!!
Thanks to all involved, I don't have to break her for spares!   s:shock: :shock: s:shock:
cabbydave
I much prefer to save a car than scrap one
PhilMC
Well done CabbyDave, great to see a good outcome with this one.
Ex-1zz and 2zz 2005 Roadster owner  \":flame:\" .
cabbydave
I couldn't see Bazza scrap his car for the sake of a chip and a ecu. Talking to Baz hes a nice guy and does a lot for others when hes not driving a truck. Good luck and stay safe on the roads. By the way I always give a wide birth for bikes filtering so no need for the blues with me.
ancient mariner
Quote from: "bazza"Hi all,
Nice one cracking result and good to see we have such good people willing to help us out.
Paul.
