2005 1ZZ piston ring update
Started by Ian3360, November 17, 2016, 09:02
Ian3360
After some in depth investigations on the UK MR2 Roadster Owners group, we think we have come up with definitive (sort of) information of when MR T applied the final update to the piston rings on the 1ZZ to try and sort the oil burning issue.
It appears that the key chassis number is JTDFR320300074980. That car was fitted with engine number 1ZZ2335488 as far as we can tell. Any engine after that should have the new pistons. That's factory engines, not reman (remanufactured short blocks) which also have them.
This is extrapolated from a Toyota Technical report which shows the update was implemented in July 2005. Hopefully this will provide some comfort to those lucky few owners that have later VIN numbers that mean they have the updated piston rings.
Personally I discovered that as my own cars VIN number ends 74978 I missed out by two cars.....  s:cry: :cry: s:cry:
S10 TRD "Slow Turd" - Sable 2006 roadster. Red leather, Widermuller bling, Frenzy Stylebar, Piranha brake discs, HEL brakelines, Simon Tan style headlamp covers, TTE Exhaust, Ducktail Spoiler, Matts Brace, Cusco strut braces, ZunSport grilles, Dev\'s Keyhole covers, Kriss\'s Kick panels, AppRadio 3 stereo, Nathans bushes, Crystal Black indicators, TRD Sportivo shocks and springs, full polybush replacement with Whiteline ARBs, [strike]Rota GT3 wheels with Yokohama S Drive tyres[/strike], Full Bodykit, [strike]AEM induction kit[/strike], C-One scoops.
[centre]CHECK OUT THE UK MR2 ROADSTER OWNERS GROUP ON FACEBOOK[/centre]
cptspaulding
& yours is 2006?
Yes, I'm afraid that 'stuck control rings only affect PFL cars' is a myth.  I've now come across 2 FL engines with the problem.  Keep yer oil changed peeps.
Quote from: "Carolyn"Yes, I'm afraid that 'stuck control rings only affect PFL cars' is a myth.  I've now come across 2 FL engines with the problem.  Keep your oil changed peeps.
Going to check my vin but have been saying for ages that it needs to be a late FL model.
Matt performance told me that.
Ian3360
Quote from: "cptspaulding"& yours is 2006?
The change was implemented on the production line in July 2005.... I missed out by 2 cars....my car was registered in the UK in January 2006.....  s:cry: :cry: s:cry:    s:cry: :cry: s:cry:
disssoof
Just checked my 2006..
VIN ends with 75341
Happy days   s:) :) s:)
But oil changes will still be completed at regular intervals..
Guess my 2005 has no chance then.
Good thing I spend a fair whack on oil (although I am late for my 6 month change)
andyroo104
Mine was fitted with a replacement short block under warranty by Toyota in 2007 and confirmed to have the new pistons.
Sent from my SM-T810 using Tapatalk
Eastsoutheast
I have a 55 plate (registered September 2005) with the following Vin,
JTDFR320500073766
My last 5 numbers suggest I dont have the latest engine but if you go from the first number mine would appear later - 3205 VS 3201
Does this mean I do have the latest engine?
Brian
Ian3360
Quote from: "Eastsoutheast"I have a 55 plate (registered September 2005) with the following Vin,
JTDFR320500073766
Brian
Afraid not Brian.....I'm told the first part of the number relates to the plant it was made at.... Mine starts 3203....it's the last digits that count   s:cry: :cry: s:cry:
Check you engine number.  On a flat part of the block casting above the gearbox.  Need a mirror to see it.r
grog
this is very interesting, i'll have to check our 2006 to see if it's ok or not,
i had previously assumed it was good, as it was a FL.
Quote from: "grog"this is very interesting, i'll have to check our 2006 to see if it's ok or not,
So many people do this so you arent alone.
I would be pretty confident of an 06.
swiftyds
Not sure that applies (06 cars are ok). Mine was registered June 2006 and is OK, but I'm only 180 on from VIN number where things improved.
I've just bought an '06....can someone describe a bit more accurately how to locate the engine number. Cast into the block?  Upwards facing or sideways....?
Vertical.  Stamped in top of the block on the left facing to the left. need a small mirror.
smarty72
Quote from: "gdbd59"I've just bought an '06....can someone describe a bit more accurately how to locate the engine number. Cast into the block?  Upwards facing or sideways....?
Easiest way is to look on your V5.
current: Astral Black FL
Ex: Forest Green 2003.
alancsalt
I've got an '04 that doesn't burn oil. Precats cleaned and regularly serviced.
Toyota MR2 Spyder, November 2002, Engineer approved 2001 Celica 2ZZ motor and C60 trans, MWR Carbon lined synchro set, SMT to Manual conversion, PPE headers,Fabricated Cat/Exhaust, Power FC ECU
