Air filter suggestions?
Started by shnazzle, December 9, 2016, 16:16
Need to replace the cone filter in the turbo, it's falling apart.
Any suggestions?
Current one is a rather large no-brand dual cone (little cone in the top)
Internal neck diameter 90mm
Filter height 132mm
Filter base diameter 150mm
Top diameter 120mm
Not bothered about the material as long as it flows well  s:) :) s:)
I got an ebay special tbh.
I hit 12psi on cold wet days so it flows well enough.
Assume it filters ok.
Cheap enough to bin every 12 months and buy again.
Mine's just got an Apexi on it. Something like this I guess - http://www.ebay.co.uk/itm/like/182356244218
Ah OK so basically any old ebay jobbie will do.
The RAM AIR one looks decent enough and is the same size.
Foam filter though.
