Aerial Problem electrical
Started by Reeflodge, December 10, 2016, 08:39
Reeflodge
I am fitting an electric aerial I bought from a breaker who swears it went up and down all the way before he removed it.
I have fitted it to the car and its not working.
There no sound coming from the motor at all.
I have looked inside and the nylon cord is not broken.
I have put a multimeter on the cables and it reads as follows
Blue wire 12v with ignition on and off
Yellow wire 12v only when ignition is on
Aerial is grounded properly
Is this how the wires should read?
Is this aerial knackered?
2000 PFL Yellow MR2 Roadster
http://www.fredwoodman.co.uk
cabbydave
Have you checked the black relay for the aerial under the drivers side rear bin? If all else fails put your other one on and wire it like I told you.
Reeflodge
Like you told me?
When?
Reeflodge
What check should I do on the relay
cabbydave
Sorry thought you were someone who bought a aftermarket aerial on fb then a breaker in Scotland sold you a aerial
Reeflodge
Dooh
Aerial Relay was missing.
Now got one and its working!
