Oil leak
Started by Brizee67, February 2, 2017, 22:07
Brizee67
I have what looks like an oil leak on the right side of the block...I'm guessing it's the timing chain seal??? ...but I don't really know. I need to run it into a garage to get it checked out.
I found this on Fleabay ( m https://www.ebay.co.uk/itm/182072857141 m  ) and wondered if it's worth a punt or should I just take it to a garage or attempt to fix it myself ?
What are your thoughts??
Likely. Get a new o-ring from Toyota and change it yourself. Get a can of brake cleaner and spray that area clean. Then watch it for further leaks. If  Ieaks... Saved yourself a lot of cash for a 15 min job
Brizee67
Quote from: "shnazzle"Likely. Get a new o-ring from Toyota and change it yourself. Get a can of brake cleaner and spray that area clean. Then watch it for further leaks. If  Ieaks... Saved yourself a lot of cash for a 15 min job
Ah, so it's a simple o-ring...I think even I could manage that...though not sure what I'm doing whatsoever...I think maybe I should invest in a workshop manual.
brettfield999
Who needs a workshop manual when you have YouTube  s:D :D s:D   s:) :) s:)
 m https://www.youtube.com/watch?v=FFQYgM96wiU m
[strike]2000 Blue PFL MR2 Roadster with 187K, engine blown[/strike]<br />[strike]2000 Blue MRS, 80K[/strike]<br />[strike]2001 Blue PFL MR2 Roadster 131K, 2ZZ,[/strike]<br />[strike]2003 Silver FL MR2 Roadster with 81K now daily driver, 2ZZ by Headcase[/strike]
Brizee67
Quote from: "brettfield999"Who needs a workshop manual when you have YouTube  s:D :D s:D   s:) :) s:)
That's absolutely perfect at least now I know how simple it is...I'd better get onto Mr T tomorrow for that o-ring.
Thank you [emoji4]
Who needs a workshop manual when you have this site.
Garage = last option; not first.
Brizee67
Quote from: "Ardent"Who needs a workshop manual when you have this site.
Very true Ardent [emoji846]
PM me and I'll send you one of my special slightly-better-seal O rings.  Also, in the 'How To' section, take a look at understanding you chain tensioner.
Brizee67
So I thought I'd take a quick look in the engine bay for the timing belt tensioner....I found it......but isn't it missing the stud on the lower section?? How is that nut holding on??
Guessing the nut seized onto the stud, so replaced it with a bolt instead
Brizee67
Is that definitely a bolt? It looks to have a hollow in the head if it is...I assumed there was a hole there. I tried to take a better picture......but I don't think it's much better.
That's a bolt.  It will do the job just fine.
Typical leaky tensioner oily mess.
Brizee67
Quote from: "Carolyn"That's a bolt.  It will do the job just fine.
Thank god it is a bolt and not a sheared spindle.
I can always take a few more pictures if you want some for reference for the 'how to..' guide.
Brizee67
Carolyn a big thank you to you [emoji122]my o-ring arrived in the post yesterday...you're a star!!
Now where's my 10mm spanner??
