Cylinder Head Bolt Socket - What Size?
Started by Namastebuzz, March 29, 2017, 16:28
Namastebuzz
Is it 8 or 10?
Can I just get a 12 point Double hex bit Socket or is it a specialized Toyota bit? I realise they're different from XZN bits.
maybeturbo
Toyota are normally just 12 point sockets. I've not seen the head bolts on this engine though. It will most likely be a 10mm or 12mm 12 point socket. May or may not need grinding the edges down for clearance.
beavisrules
Pretty sure standard 10mm bi hex.
was something in a big set I already had so definitely not special.
