M1tch's long term 1ZZ build - Project 11
Started by m1tch, April 8, 2017, 19:12
m1tch
#250
I have just re-read a message from TCB with regards to the forged pistons, it would seem that I am able to order the pistons in either 79mm or 79.5mm - all other aftermarket pistons seem to only come in 79.5mm, 82mm or 82.5mm meaning that I might be able to run with a 'drop in' forged piston at 79mm - as you would do on a standard rebuild for the oil burning issues.
Need to get the spare block checked over in terms of bore size, might have to take it to a machine shop although I am tempted to get myself a bore gauge to check it over myself, I can still see the hone marks on the cylinder walls so I think the engine is low mileage.
Looking at the Toyota workshop manual, for the stock bores to be reused they need to be 79.000 mm - 79.013mm (3.1102" - 3.1107") - Although not sure if this is correct as this would mean that the bore must have less than a fraction of a mm - unsure if this should be 79.000mm  to 79.130mm as the next stage mentions that if the bore has less than 0.2mm of wear you can remove the carbon build up at the top of the cylinder.
AllanE
#251
You can get ductile iron liners from Westwood Cylinder Liners (in sunny Droitwich).
I got mine off Ebay for about £150, IIRC,  (but that was a few years ago) and had them fitted by Scholar Engines (sunny Stowmarket) for about £300.
m1tch
#252
Quote from: "AllanE"You can get ductile iron liners from Westwood Cylinder Liners (in sunny Droitwich).
Would rather go with Darton sleeves, have been quoted £120 per bore to fit the liners, have decided to simply bore the engine out to 79.5mm and run on stock sleeves - I can then use the project budget on something else, won't be running huge power as I won't be fitting an E153 box so just limited to the uprated JUBA gears in the stock box.
m1tch
#253
I have now taken the head apart, it would seem that the head is in good condition, not a huge amount of build up on the valves (although not too worried about those as I am swapping out for an upgraded valvetrain).
I have also invested in a set of micrometers to then get the crank specs to see what bearings I need to order, I have a feeling they will all be standard size as I can't see any wear on the crank etc.
I did however noticed that there was a code on the bottom of the cylinder head which started with '4zz', I know that the 1zz, 3zz and 4zz engines have the same head - as far as I know this engine hasn't been opened however if it is indeed a 4zz head it has been rebuilt at some point. I am not too concerned if it has been rebuilt as it means that the valve guides and seals are going to be newer etc and they all look to be in very good condition.
Next step is to get the crank checked for size so I can then order the main and big end bearings - its the only thing that is currently holding up the build at the moment, after I have the sizes to put in the order I will then have the pistons to take to the machine shop to then be able to bore the block out to 79.5mm and start assembling up the engine.
Plan for parts is currently:
79.5mm pistons - custom from TCB
Forged rods - custom from TCB
Crower stage 2 forced induction camshaft
High flow black nitride coated valves
Upgraded valve springs and retainers
ARP head studs
ARP main studs
ARP flywheel bolts
Lightened flywheel
Fuel injectors - still to be decided
Clutch - still to be decided
New OEM oil pump
New sump (drilled for turbo drain but blanked)
m1tch
#254
I have now fitted an induction kit behind the battery, it consists of:
45 degree 70mm silicone pipe
Cut up top of OEM airbox for the MAF tube and bellmouth
Generic induction kit filter
Its fitted behind the battery and the intake temps aren't bad due to being shielded by the battery as well as airflow from the passenger side vent.
Initial impressions are very good, car feels like it has more midrange torque vs the stock box and does feel smoother than the stock box - sounds really good as well.
MilesH
#255
Following this with interest, great thread!
If you wouldn't mind me making a suggestion......pics as you go would be great  s:) :) s:)
m1tch
#256
Quote from: "MilesH"Following this with interest, great thread!
Will try and get something up for you, its very very basic, key thing is the MAF tube though so worth finding a spare airbox to then cut the tube out etc.
In engine building news, I need to recheck my crank, I think I had an issue with the adjustment of one my micrometers - I set it using the 50mm standard but have now adjusted it using the 25mm and 50mm standards and it seems to check out. Will be getting some plastigauge in various sizes anyway so no real harm in checking the current bearing clearances - will still look to fit performance bearings though.
m1tch
#257
I have just ordered a few parts from TCB which are very competitively priced, parts ordered so far are:
ARP Main studs (block is going to stay together)
ARP Head studs (head is going to stay on)
ARP flywheel bolts (flywheel will stay on)
Custom TCB Link G4+ plug and play wiring loom for my Link Xtreme - will be adding in a MAP sensor, high speed IAT sensor and a doughnut knock sensor at some point when I get onto boosting the engine
TCB replacement lower UJ - I think mine is a bit past it so wanted to refresh this before the summer for safety
Needed to get the main studs as I need to check the specs on the crank to see which bearings I need (or if I need to grind the crank), I have a set of plastigauge on its way so once I check the spec on the mains and crank pins again I can order up bearings and check the oil clearances.
lamcote
#258
Nice.
Does the TCB wiring loom for the Link ECU keep the standard ECU wired in (kind of "piggyback"  style) to run the dashboard, immobiliser etc?
m1tch
#259
Quote from: "lamcote"Nice.
As far as I know its a fully standalone ECU (although I have not seen the harness), with the same inputs and outputs as the stock harness, as far as I know the alarm and immobiliser are separate control modules, the mileage etc is held within the speedo.
I will report back when it arrives - I do have the Link Pin kit A and B so I could probably wire it in myself but felt that it would be more reliable to get the plug and play harness with all the connectors that have been tested etc.
lamcote
#260
My understanding is that you need to keep the standard ECU wired in for certain functions such as the coolant gauge.
The Monkeywrench standalone ECU runs as a standalone ECU for all engine functions but retains the standard ECU wired in just for these functions because the standalone ECU doesn't include them.
It's all a bit complicated but the solution seems to be retaining the standard ECU but bypassing all the engine control elements which is presumably done by an appropriate design for the loom?
m1tch
#261
Quote from: "lamcote"My understanding is that you need to keep the standard ECU wired in for certain functions such as the coolant gauge.
I will find out when it arrives - its one of the reasons why I opted to buy a plug an play loom so that I didn't have the headache of trying to work out where everything plugged in!
Probably won't be installing the ECU for a while though, just enough to power it up and unlock it, set the various sensors up and turn the key.
Plan moving forward will be:
2018
Enjoy the car on the stock engine running the stock ECU or maybe the PFC with a tuned NA map installed (although checking parameters before I rely on the tuned map that is on there)
Fit steering UJ
Swap out exhaust for more compact custom exhaust
Fit coilovers and bushings
Build up the forged engine
MOT expires on 31/07/2018, car will be MOTed with the stock engine, after this point I will look to swap over engines if its ready
2019
Fit the forged engine into the car if its not already in
Run the car NA on the stock ECU/tuned PFC
Start collecting parts for the turbo upgrade
2020
Fit turbo parts
Fit Link ECU and get car mapped
Previous versions of the link still required stock ECU to run parts of the dash.
I don't think this has changed.
Getting a loom for an ECU you aren't planning on fitting for a couple of years is some serious forward planning.
I planned to do this to mine and then went V6.
Plans change.
Still interested to see what you do gearbox wise.
Good luck.
lamcote
#263
Presumably if the loom is designed correctly it would allow retention of the standard ECU and include appropriate connections to connect into both the Link and the standard ECU as required?
Is that the solution or is there more to it than this?
m1tch
#264
Quote from: "1979scotte"Previous versions of the link still required stock ECU to run parts of the dash.
Plans change.
Good luck.
This is probably the case, will find out when I get the PnP harness and shall report back, guessing that the PFC would emulate the stock ECU as a standalone (much like the PnP Link ECUs for other Toyotas).
I am forward planning quite a bit, it was a good price and has all of the features I needed so I just went with it. The reason I am not going to fit it right away (apart from unlocking it and checking out the software) is that with the engine running NA, remapping the ECU will boost the power from 140 to say 170 or so. Whereas remapping with the turbo setup will go from 140 to 400 - the dyno time will be the same so its more cost effective to run on what I have for the time being as I don't really want to be remapping more than I need to.
I will be running JUBA 3rd and 4th gears in the stock 6 speed box - I have found someone who is running a stock C60 box with a turbo setup running 300ft/lbs, apparently 4th fails every now and again but its on a stock box. I will look to limit the torque when I do remap to ensure that there aren't any sudden increases in torque through the rev range.
I must say I did also look at some of the Rotrex superchargers, it would seem that the C30-94 should support the airflow, will look into this option as well but am still favouring a turbo.
Block will be a sleeved 82mm setup, still working on piston options for the UK, might have to import but will work through the numbers - have found a machine shop that does 1zz supply and fit Darton sleeves, either dry sleeves or the Darton M.I.D. sleeves which would be the more desirable option. Also looking at block guards as well as pinning the sleeves but I think if I go Darton M.I.D. it should be fine.
Currently researching:
King vs ACL bearings
Tool steel wrist pins
Cometic head gasket thickness
Fuel pump options
Intake manifold mods needed
m1tch
#265
I have had a slight change in plan with regards to the engine strengthening, instead of going for sleeves I am now going to look to run CSS (Cylinder support system) which is a custom CNC machine piece that is installed right at the top of the OEM sleeves. This then makes the engine a semi open design and allows for the sleeves to be held securely so that they don't move (and then crack) under higher loads, its quite common on Honda engines it would seem.
The CSS isn't the same as a block guard as a block guard is simply press fit into the engine and isn't specifically machined to the engine its being used on - more of a generic part.
This means I will be looking run the CSS, stock sleeves and a slight overbore to 79.5mm - I have been informed that the CSS is rated to around 500whp which should be plenty, its also worth noting that I have seen a few videos and builds where Honda engines have run 1000bhp on stock sleeves but CSS.
I was dead set on getting the engine sleeved but I also realise that even with the engine with dry liners, the engine is still an open deck design with no real support at the top of the cylinders where it needs the support the most.
I am still researching into it but it seems likely I am going to go with the CSS with 79.5mm forged pistons - considering I was originally planning on simply boring out to 79.5mm and keeping the rest stock I am happy that there is another options out there and great that there is a solution to give extra support to the top of the cylinders. I was even looking at pinning the sleeves by tapping the block to insert pins through to then support the walls of the sleeves.
m1tch
#266
Quick update on the build so far:
Harness is currently being made - its a piggyback style so the stock ECU will look after some parts of the running of the car, Link Xtreme will look after the mapping, will be using a newer style MAP sensor, fast response temp sensor and will be upgrading to a Bosch doughnut knock sensor.
With regards to the block, this is going to be sent off to get the CSS machined in, will be running stock sleeves and 79.5mm bore, 10:1 compression ratio - I believe I will be the first person in the world to have a CSS 1zz and I believe this could be a better option than getting the block sleeved (unless going for an large overbore). Even with sleeves fitted the engine is still open deck so there is still no support at the top of the (now much thinner) sleeve. I will be getting a quote for how much it would cost for the block to be sleeved as a comparison but won't be sleeving the block.
I also have a T3 turbo manifold arriving soon so I can look to test fit this onto the engine to check clearances and turbo supporting etc - as mentioned I won't be bolting a turbo on right away but can start to collect parts etc.
With regards to engine bearings, there are currently no race bearings for the big end bearings but the main bearings for the 1zz and 2zz are the same, the plan will be:
Run King race bearings on the mains - MB5375XP (alternative is ACL race - 5M1857H/HX)
Run ACL or King standard bearings on the big end but run with a dry film coating to upgrade the standard bearing to a more race friendly bearing - King CR4263SI /ACL 4B1851
10:1 compression ratio is going to give good off boost performance and aid turbo spool but will limit you up top.
MWR only recommend them for low boost applications.
As an example the 3s gte has 8.8:, the 2jz gte is 8.5:1 and even more recent engines like Subaru's ej25 have a compression ratio of 8.0:1 - 9.5:1 on their turbo applications.
Just my thoughts.
At 10:1 with a turbo that big you're going to want to consider using the temperature safety features of the Link to reduce timing when it gets stupid hot.
Just one extra sensor (possibly two if doing IAT and EGT) and a bit of config. Small and price to pay for saving the block
m1tch
#269
I am still deciding between the 8.8:1 or 10:1 pistons - the engine shop has mentioned that they have quite a few high power cars running 500bhp running 10:1 pistons without issue when running on Vpower etc. Will be running upgraded IAT sensor as well as upgraded knock sensors etc and will definitely be running knock control on the Link.
Might look to run the 8.8:1 to be safe, still deciding on that though.
m1tch
#270
I now have a turbo manifold, its a OBX T3 tubular manifold, actually very impressed with the fit and finish of it, flanges are very thick and there has been work to blend in the pipework (not just welded together and left).
It also came with a t25/t3 adapter as well which included decent studs and copper nuts (will be getting some more for the rest of the manifold at some point.
It will mean that I have the possibility of running a T25 turbo first then upgrade to a T3 turbo at a later date, I believe the wastegate flange is 38mm so not massive but should mean I can run whatever turbo I want.
Might look to mock a few things up this weekend to check clearances, I believe its a bottom mount but will find out soon!
Sounds good.
m1tch
#272
Will initially be running the engine NA on the stock ECU for probably most of next year to break the engine in and enjoy the car more knowing that the engine is sorted so I can put my attention towards other aspects such as suspension as well as collecting additional turbo parts etc.
Just thinking about mapping when I do go turbo, will have the option to run without a MAF - will initially look to run the stock MAF/upgraded Subaru MAF first and add in the MAP sensor as well. My issue is that if the car is mapped using the smaller turbo without a MAF and I then bolt on the larger turbo, the MAP readings would be the same but the airflow would be higher - eg more air flowing at lower boost then before. Means that I think it might be best to run the car with a MAF and base it on airflow so that I can swap to a different turbo in the future. As the mapping would be airflow based it would mean that if I swap out the turbo it will just look at the fueling on a different part of the ECU map - will talk to a tuner about the options though.
Might be able to find a much larger MAF to avoid any restriction in the intake as the ECU should be able to be configured for whatever MAF is plugged in, would just need to find the correct voltage vs airflow etc.
Currently in the process at looking into the main and conrod bearings though, will look to get the block sent away for CSS soon though.
Supra MAF?
That must support a large flow or as you say the Subaru MAF.
I was lead to believe that MAF was actually better than map but that MAP was far easier for aftermarket implementation ie changing the size of your induction pipe doesn't screw with a MAP but does a MAF. MAP doesn't cause any air flow restrictions etc.
It's about finding a MAF that supports your power goal in the correct size pipe.
Evo X uses both.
With my DET3 piggyback I will probably keep the MAF even though it has an in built MAP sensor and ability to delete the MAF.
We shall see.
I just had the same selling speech in favour of MAP.
But advised only in combination with after-turbo intake air temp compensation.
The main reason being safety and not having to faff about having to map in the flow to load mapping.
Any leak or pipe disconnecting on the intake on MAF and you're stranded. With MAP, as it goes off manifold pressure, it'll just keep trucking on.
But get the mapping of the MAF right and it's a lot more accurate across the range.
If I were to be building a turbo I'd go for MAP
