SOLVED! - shin Etsu Silicone sealant 45 - or equivalent
Started by jvanzyl, April 13, 2017, 17:05
Hi Folks,
It appears that there is a bit of waterproofing required with the use of EDFC motors... turns out you're supposed to use something like shin Etsu Silicone sealant 45 or an equivalent.
The only place I can find in my brief googling is this:
 m https://chilternconnections.co.uk/produ ... 30ml-white m
and it AINT cheap!!!
Does anyone with the appropriate chemical knowledge know of an equivalent that could perhaps be a bit cheaper??
Many thanks!
John
EDIT: - Thanks to Chris, I found the company Intek who supply something called XTS 320  m http://www.intek-uk.com/heat-resistant-sealants.html m  which is a high temp silicone sealant.
AND they actually sell direct  :-) :-) :-)  so from the princely sum of like £8 I'm sorted!  :-) :-) :-)
Essex2Visuvesi
Looks like a general silicone sealant to me
I've just asked some formulation chemists at work.. one reckons normal silicone will do the job, the other reckons there's a big difference! arrgh...
Essex2Visuvesi
I'd say any RTV automotive grade silicone should be fine
hmmm..... I shall drop by the local auto store and see if they have something that looks safe!
ChrisGB
Three aspects elevate this above the average  RTV..
The thixotropy will keep it from running when applied.
There is no acetic acid outgassing.
The service temperature is very high for this kind of material.
Quote from: "ChrisGB"Three aspects elevate this above the average  RTV..
Chris- you sound like you might know something about this.... Would you be able to recommend an alternative?
ChrisGB
Quote from: "jvanzyl"
I'll delve into it when i get a chance, I've been struggling this week, it's the first day my temperature has dropped below 39C all week, so still well out of it.
Eeshh! You ok man???
ChrisGB
Quote from: "jvanzyl"Eeshh! You ok man???
Some sort of flu I think. Feeling considerably better today, may go to work.
Try Intek RTV382. The may be cheaper options too. I'll dig around when I get in.
Well.. glad you're on the mend!
Thanks for the link of the intek stuff... I'll go for that I think as it seems comparable....and half the price!  :-) :-) :-)
ummm.. yeah... so the one place that I can find to buy the intek stuff is saying minimum order of 12!!  .. will persevere...
