Anyone looking for a remote transponder?
Started by smarty72, April 25, 2017, 14:54
smarty72
Just received successfully paired a replacement key fob purchased via a well known auction site.
The seller appears to have several other identical looking transponders if anyone is looking for one at the moment.
Not sure if I'm allowed to post a link but can post or PM item no's if anyone wants one.
current: Astral Black FL
Ex: Forest Green 2003.
ducatiross
Hi Smarty,
I'm having immobiliser problems with mine so I wonder if I got a new key fob it might stop the issue. How do you do the programming so the immobiliser recognises the new fob ? Could you send me the link so I can see it on ebay ?
thanks
@ducatiross
Little linky here for you.  As I had to do the same.   s:-D :-D s:-D
smarty72
Quote from: "ducatiross"Hi Smarty,
thanks
Looks as tho Stu has sorted you out, good luck with it.
Treboeth
Posting Ebay is not allowed   s:wink: :wink: s:wink:
But when it`s helping out other members(as in this case ) a rather than pushing your own items for sale no one minds   s:D :D s:D
ducatiross
StuC - thanks for the link - I'll give that ago.
Smarty - If you could PM me with a suggestion of where to look for a decent replacement key that would be most appreciated !
Let us know how you get on with your pedal dance.   s;-) ;-) s;-)
ducatiross
Right, I know it's a year later but I finally fixed this !
Well, if you can call spending £500 at your local Toyota dealer 'fixing' it.
Turns out that there is an amplifier on the ignition barrel that sends the signal to the immobiliser. Mine wasn't amplifying enough. One new one later and she starts first time every time ! Red LED goes out even when the key goes anywhere near the barrel so must be pumping out 1000watts of amplified power !
Still, I know it cost a lot but the first drive after waiting all this time was worth EVERY penny ! Reminded myself why these cars are so special !
So, I'm not sure if you can do this as a DIY using a a scrap car amplifier but I hope this helps anyone with the same problem.
DucatiRoss
Well done on getting back on the road.
however... just to assist others with the same problem:   The amplifier does not read or carry codes.  It is just an interface between the chip in the key and the ECU (which does the code reading).  So a working used one from a friendly breaker will do the job.
See:
 m https://en.wikipedia.org/wiki/Transponder_car_key m
