Exhaust wrap, what length?
Started by andyb, May 16, 2017, 00:07
andyb
After reading all the threads about manifold pre-cats breaking up, checked mine.They were still fine after 72,000 miles  s:) :) s:)  , then I removed manifold and smashed them out, potential problem solved.
All the nuts holding the manifold came out surprisingly easy, unlike the lower heat shield bolts that sheared off but not to worry I'm going to wrap them instead.
Question? What length do I need to and is there any recommended wrap to use or are they near enough all the same.
mr mr2
I just got mine from eBay 1 roll did mine was black when put it on now white from the heat think it was 2 meters Make sure you get lots of metal ties
Excelsior
andyb
Cheers for the reply.
10 metres.  It needs a 50% overlap.  It's surprising how much you need.
