Brake and steering fluid leaking!
Started by SombreroPeak, May 29, 2017, 22:04
SombreroPeak
My handbrake light came on yesterday and is basically on all the time now. Having a quick search on here it seems this is due to low brake fluid. Adding this to my leaking power steering fluid and my poor car needs some surgery!
I bought a set of HEL brake lines the other day, so hopefully that'll sort that...once I've worked out how to fit them and bleed the system...
Similar with the leaky steering pipes, got the new ones, pretty sure it's just a question of emptying reservoir, 'unbolt' old and 'bolt' in new, refill, burp by lock to lock while jacked up.
\'N-chilada\' 2003 Chili Red, Black Leather interior
brettfield999
Before you replace the hoses, you must identify where the problem is coming from.  You'll only have to bleed them again which in a word is LONG.  Is the brake reservoir low? And do you get a loss of braking at all.  Don't drive till you find this out
[strike]2000 Blue PFL MR2 Roadster with 187K, engine blown[/strike]<br />[strike]2000 Blue MRS, 80K[/strike]<br />[strike]2001 Blue PFL MR2 Roadster 131K, 2ZZ,[/strike]<br />[strike]2003 Silver FL MR2 Roadster with 81K now daily driver, 2ZZ by Headcase[/strike]
SombreroPeak
Thanks brettfield999,
I've not had any loss of braking, but you make a great deal of sense, I'll have a look first thing and see what I can find out...I know where the brake reservoir is which is a start!
The Other Stu
As a relative newb to this stuff, something I learned yesterday when wondering where all my brake fluid was going (in my case, I left the bleed valve open)
Take the wheels off. Get someone to pump the brake pedal. You should not only be able to see the leak, but as it's at high pressure, chances are you'll hear it too!
tomaky
Check the reservoir before you do anything. if theres nothing in it fill it up, pump the brake, if the level lowers you will have a leak.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
SombreroPeak
Thanks The Other Stu and Tomaky,
I had a look at the reservoir and it was low, but only just below the MIN mark. Topped it up, but didn't get further as I was running out of time and also wanted to see if I could make any progress with the power steering pipes.
Sure enough the leaking is pretty obvious. So I began to take pics so I could make a How To, but would you believe it I was stumped at the first hurdle...
No matter what I tried, I couldn't release the spare wheel! So couldn't remove the box to access the pipes!  Popped down to the local friendly garage and they're going to take a look at it on Friday. I wanted to do the job myself, but just don't have the time now.
There's a fair amount of surface corrosion all around the frunk, so this summer I will pick a few days of dry weather and really tackle it.
SombreroPeak
OK, pleased to report that my new pipes are now fitted, but slightly ashamed that I farmed the job out. £60 +VAT and I supplied the fluid to be sure it was right. Still, peace of mind that they will now last, and I won't have to fork out for more of Mr T's finest brew. I will give them a coat of something in the near further...any suggestions?
He took a look at the brakes too as I am losing quite a lot of fluid and it turns out to be my drivers side rear caliper. So on the hunt for a good second hand one...stopped in at Halfords for a small pot of red Hammerite smooth as I like what others have done to their calipers.
SombreroPeak
Apologies for my ignorant questions, I'm learning all the time...  so having been topping up the brake fluid every other day, it's time to swap over the old leaking caliper with the new one...painted as you can see...
Problem is, the 12mm bolt I've pointed to below is rounded, so how do I get it off?
Also, where do I get a replacement bolt from too? Halfords off the shelf job?
That's a very specific bolt, Toyota part, I'm afraid.  The thread pitch, the length of the plain section and thread length are just not 'off the shelf'.
SombreroPeak
Thank you very much for such a quick reply Carolyn! Oh well, bolt it all back up and I'll order it in tomorrow...sniff sniff...
brettfield999
Quote from: "Carolyn"That's a very specific bolt, Toyota part, I'm afraid.  The thread pitch, the length of the plain section and thread length are just not 'off the shelf'.
I cant see properly but isn't he pointing at the caliper slider bolts?  If so once removed you can get a kit of ebay for a tenner asI have a set.  I've been proved wrong before though lol
smarty72
If I've read this correctly, then the garage said that it's the calliper that's leaking.  If that's the case, then where has the fluid come from that's all over the brake line and surrounding area in this picture;
current: Astral Black FL
Ex: Forest Green 2003.
Just realised - you still need to separate the two parts of the caliper.  Cut the head off the bolt.
gazza1286
It's unlikely to have two leaks. If the only obvious dampness is around the pipes then that's the problem. If there's no dampness on the caliper then it's not faulty.
Cutting the head off the bolt isn't the solution as the bolt must be fully withdrawn to allow the caliper to be removed.
The rounded bolt isn't normally a major issue but you'll need a set of locking pliers (mole grips) at least 10" to undo the bolt.
The replacement bolt can only be sourced from the dealer. It's only the slider pins for the front calipers which are available as aftermarket.
Even if the caliper isn't the source of the leak you need to address the bottom bolt as the sliders really need lubrication at least annually as the rear calipers are notorious for being the route cause of braking and handbrake problems.
If the caliper has been neglected you'll also find that removing the handbrake cable pin will slow you down. This might help:-
 l viewtopic.php?f=11&t=54813 l
Quote from: "gazza1286"It's unlikely to have two leaks. If the only obvious dampness is around the pipes then that's the problem. If there's no dampness on the caliper then it's not faulty.
If the entire caliper assembly is off the car (does not need to be separated to get it off), then you can slide it apart by cutting the head off the bolt.
gazza1286
Good point Carolyn. I've not had to go that route previously as the bolt has always been coaxed off will my mole grips. This leaves the car drivable until the replacement bolt comes through from the dealer.
You could also put some heat into the area around the threads (no rubber bits to fry in the vicinity) and the old mole grips might still do the job.
Edit: you might fry the rubber on the other side of the thread... easy to replace, though.
SombreroPeak
Thank you all for your replies. The other fluid is WD40 to prep the pipes for changing. I think my only option is to order the bolt in and go from there. Given that the power steering fluid was so expensive, what will I be looking at for this little part?
less than a tenner.  I did buy one last year, don't quite remember.
Toyota Parts Direct on the old interweb.  They're a bit weird to deal with as they always want your REG No., even when the part fits every car, but the dispatch is quick.
gazza1286
BTW - if you're planning to swap the flexi too (and the nut isn't yet rounded) buy a brake pipe spanner as you only get one chance.
 m http://m.ebay.co.uk/itm/Draper-Brake-Pi ... Ciid%253A2 m
SombreroPeak
Perfect, thank you. I'll take a look. Is there a part number or exact name I need?
I think I used 'rear brake caliper slider bolt'.
SombreroPeak
Just a quick update, I found the bolts at MR2-Ben at £1.73 for a single or £3.46 a pair so have just ordered two. Can't copy and paste the link on my phone, but easy enough to find. The site says it is suitable for all Mks and is a genuine part. Not sure how quick delivery will be, but hope it won't be too long as I don't like driving with the leak as it is.
Bossworld
Mole grips to remove the rounded bolt and they're less than £2 from Toyota, mine were proper buggered when I got the car
SombreroPeak
Slider bolt pair arrived today, very impressed with delivery time.
Just been reading up a little about how to go about this job, and beginning to wonder if I'm biting off more than I can chew? Bearing in mind I don't know much, but am pretty handy with practical stuff. Is removing and replacing the rear caliper straight forward or do I need to know special knacks of doing things and do I need any special tools?
Just don't want to get frustrated and lose the whole weekend and still not have a roadworthy car by Monday...
Sorry for all the questions.
